38 posts / 0 new
Last post
Joshuamessenger's picture
Last seen: 3 years 1 month ago
best way to clean piano black
how to go around cleaning my turntable and subwoofer, with out adding scratches
sorry if this is a little off topic on this from !
scene's picture
Last seen: 3 days 20 hours ago
RE: best way to clean piano black
If you just want to remove dust, use an anti-static feather duster.
To actually clean, you could try an ultrafine and soft microfibre cloth - I mean a lens cleaning one, as no-one wants to scratch their glasses - and lens cleaning solution.
AV: Marantz SR7009; Monitor Audio RS-LCR, Silver 8i, RXFX; BK XXLS400 Sub; Pioneer KRP500a; Sony BDP-S760
HiFi: Arcam A85; AE Compact 1; Arcam DV79 (as CDP), ProJect Debut II
chebby's picture
Last seen: 6 hours 18 min ago
I'd leave out the lenses cleaning solution!
An old, well washed, soft, cotton T-shirt cut into pieces (no seams, hems or labels to scratch anything). Use a lightly dampened* piece to clean off any marks and a dry piece to 'buff it up' afterwards.
Then a feather duster in between times to scoot off loose dust.
*use a thoroughly rinsed out spray bottle to spray water onto the cloth - not the hi-fi surface - to lightly dampen it.
iPad Mini 3 • iPhone 6 • B&W P3 • Mac Mini • Apple TV3 • Quad Vena • Pro-ject Tuner Box S • Audio-Note AX-Two
scene's picture
I only siggested lense cleaning solution as it doesn't leave any (visible) residue - though distilled water would probably be as good. I just have lense cleaning solution lying around, as they give me little bottles of the stuff every time I take my son to the opticians...
And yes, I should have said, wet the cloth not the hi-fi :silenced:
chebby's picture
Lens cleaning solution is fine on glass (as is Windolene and any number of products with various chemicals and solvents in them), but the finish on a gloss paint or lacquer may react badly.
scene's picture
No that's a fair point, well made. Distilled water it is then.
Would use suggest car polish like turtle wax to give a protective layer and then use microfibre rag to buff it and then use the rag to maintain.
scene's picture
As Chebby pointed out - I'd avoid anything with any chemicals in it that could damage the surface finish. Turtlewax contains petrol distillates that could easily dissolve the finish, depending on what it is actually made of.
abacus's picture
Last seen: 3 days 19 hours ago
Email the manufacture and ask them.
Hope this helps
Bill
chebby's picture
From your REL R series manual...
"Care and Polishing
The cabinets are best maintained by using a spray-on wax, such as an automobile wax made by a company called
Griot’s. If objects are to be placed upon the top, it is advisable to use a small mat to protect the surface and to avoid
the risk of rattles.
From your Project Debut SE3 instructions...
(Click here for clearer picture.)
simonlewis's picture
Last seen: 2 weeks 17 hours ago
Avoid buying anything with piano black in the title as i have a piano black tv stand (glass) & it attracts dust like a magnet, the only advice i can give is get the wife to clean it on a regular basis or hire a cleaner. Smile
AEJim's picture
Last seen: 6 days 18 hours ago
Depends on the type of Piano Black it is, it can vary from a glossy vinyl wrap to full automotive quality multi-layer lacquer. On our piano finished speakers we always use Colour Magic (the car wax) of the relevant colour for the best shine before we box them up.
Head of Design and R&D, Acoustic Energy Ltd.
BigH's picture
Last seen: 2 months 5 days ago
I don't think it is the black that attracts dust but it will show it up, some speakers you don't have much choice ie Kef LS50s.
Listen to the music, not the hifi.
p_m_brown's picture
Last seen: 10 months 3 weeks ago
Microfibre polishing cloth and if soiled, a tiny bit of window cleaning spray. Don't need car wax unless you intend leave them out in the elements!
Clearaudio, Naim, Audio Physics
matthewpiano's picture
Last seen: 3 weeks 6 days ago
Firstly, we don't even use the term 'Piano Black' in the piano industry.  It is a peculiar term, especially as the shiny black finishes on most speakers and hi-fi equipment are quite different to what is actually on a real piano unless you are dealing with really good quality stuff.
Secondly, shiny black finishes will always show polishing swirls over time.  This even happens on £120,000 Steinway grands with really good quality black polyester finishes.  It is simply the nature of the beast, no matter how careful you are.
A soft, dry and clean cloth is the best tool, with careful use of an alcohol-based glass cleaner, sprayed onto the cloth and not the surface, where necessary.  It isn't advisable to use anything harsher than that.
Rega RP3/Elys2/TT PSU- Denon DCD720ae - Denon PMA720ae - Dynaudio DM2/6 - Atlas Equator 2.0 - Beyer DT-770PRO - Mission stands
VoodooDoctor's picture
Last seen: 2 months 1 week ago
Monitor Audio sell wax for the lacquer finish on their website.  It works well.
Pages
Log in to post comments
