1. The list in brief
2. Best overall
3. Best standmounters
4. Best upgrade standmounters
5. Best floorstanders
6. Best desktop
7. Best powered
8. How to choose
9. How we test
Not everyone has a huge wedge of cash to invest in their hi-fi system, but that doesn't mean you have to settle for poor-quality sound; there's serious value on offer from a whole range of affordable speakers.
The best budget speakers will fill your room with sweet stereo music far better than any one-box wireless speaker – and without breaking the bank. We've filtered through our reviews of the very best cheap speakers – bookshelf speakers, floorstanders and desktop powered speakers – to create this selection of our favourite performers – all under the £500 mark.
Our list spans speaker brands such as Dali, Elac, Wharfedale, Ruark and more, which just goes to show how many excellent budget hi-fi speakers are out there for under £500. We've tested every one of these speakers in our dedicated listening rooms in recent years, so you know you're getting our genuine, expert recommendation. You can read more about our speakers testing process below.
So whether you're building a separates hi-fi system or adding a pair of speakers to a microsystem (or want better sound for your TV), take your pick from our list of the best budget speakers that we've tested and can heartily recommend.
I'm the Hi-Fi and Audio Editor of What Hi-Fi? and have been testing stereo speakers for the better part of a decade, from floorstanders to bookshelf models, and across all budgets. While hi-fi can be an expensive endeavour, our picks of the best budget speakers below show you can get a whole lot of performance even when you're on a tight budget. When testing budget speakers, I look for build quality (it should still be made to a certain standard), compatibility (how easy it is to place in your room and use with partnering kit) and, most importantly, sound quality. Clarity, detail, rhythmic drive, dynamics, scale and musical cohesion – these speakers may be affordable, but they should still get your feet tapping and/or affect your emotions with all music.
The quick list
Best overall
Best overall
The best hi-fi speakers you can get for this budget price, the Elac B5.2 Debut 2.0 are easy to recommend to anyone.
Best standmounters
Best standmounters
An impressive set of standmounters that are more confident and composed than their similarly priced rivals.
A small, unfussy pair of speakers that have the capacity to take your system to the next level.
Best floorstanders
Best floorstanders
These refined, entertaining and affordable speakers should be top of your list if you’re looking for floorstanders.
Best desktop speakers
Small enough to sit on your desk but with an impressively spacious soundstage and musical sound.
Best powered speakers
Compact, affordable and well-featured, this powered pair sounds balanced and insightful.
The best budget hi-fi speakers overall
There's no shortage of talented budget speakers on the market, so it takes something really special to top our list. Needless to say, these Elacs sound sensational for the money.
At 34cm tall, they're a relatively compact single-wired design and use a 5.25cm aramid fibre mid/bass driver partnered with a 2.5cm cloth dome tweeter. The Elacs are unfussy about placement but we'd definitely partner them with quality entry-level separates - this will allow their rhythmic talents to shine through. Anything less and you're doing them a disservice.
They're dynamic and expressive performers capable of dealing with any genre you throw their way - dense instrumentation and complex rhythms pose no problems for these Elacs. In the midrange, they're a little lacking in warmth, but on the flip side, they're very well balanced and can make the best of any recording, regardless of audio quality.
Overall, they deliver sound with a precision and cohesion that’s rare for this level (although Dali's Spektor 2 come close). Elac has been making speakers since the 1980s, with a fine heritage of products to its name. These are some of its finest, and for this money, they're nothing short of exceptional. Buy with confidence.
Read the full Elac Debut B5.2 review
The best budget standmounters
Pretty much everything here is new for this generation of Diamonds, from the drive units to the cabinet construction. It's a neat and compact box – standing just 31cm tall, it won’t dominate any room. The polypropylene/mica composite 'Klarity' mid/bass cone is tuned by a rear-firing reflex port, rather than the elaborate downward-facing design used in previous models.
Tonally they’re smooth and forgiving but remain nicely balanced, with enough in the way of bite. They have a surprisingly bold and full-bodied presentation and sound confident and composed in a way that evades most budget rivals, and top that with a good degree of refinement. They deliver more authority and scale than their modest price and size suggest too.
Lastly, they're good and flexible no matter their task. They sound balanced wherever placed and are both forgiving and transparent enough whether used as part of a microsystem or put with dedicated separates – well worth your shortlist.
Read the full Wharfedale Diamond 12.1 review
The best budget upgrade standmounters
About the size of a shoebox, these Dalis keep strictly to convention as far as design is concerned; they are a two way, rear-ported design, just like all their closest rivals. And to look at, you might think they're nothing special. But you couldn't be more wrong.
For these Dalis are actually quite exceptional. They're wonderfully articulate performers that marry a bold, forthright nature with the kind of refinement and insight that’s rare at this level. They're particularly stunning with vocals, delivering them in a solid and expressive manner that really enhances the listening experience. You'd need to spend around three times as much as these to better the vocal performance - it really is that good.
Admittedly some rivals, such as the Triangle Borea BR03, are able to dig up a tad more detail, but few deliver it with such a sense of passion and enthusiasm.
Tonally they tread a fine line, with a smooth treble that's not short of bite. The full-bodied presentation always sounds impressively confident and composed, no matter what it has on its plate. Although be aware that speakers this small are never going to produce loads of bass.
Read the full Dali Oberon 1 review
The best budget floorstanders
The Wharfedale Diamond range of speakers has an almost unrivalled reputation, predominantly forged on the performance of the standmount speakers. But now, thanks to the the Diamond 12.3, we have a superb entry in the range in floorstanding form.
Smartly finished, these speakers are available in black, walnut, white and a rather classy light oak. They are a 2.5-way design where the upper 13cm driver covers everything from midrange downwards, leaving the second one to reinforce the lows. The tweeter is the 25mm coated woven polyester soft dome model seen across the range.
We found they performed best around 50cm away from a wall and with a slight angle but they're pretty unfussy and will play nicely with any price-compatible amplifier. They deliver a lovely layered sound that’s brimming with detail and dynamic nuance. Feed them a poor signal and they’ll round off rough edges and downplay unwanted aggression without sounding like they’re smothering the life out of the music.
Working well at low and high volume, you really shouldn't buy another pair of speakers at this size and price without hearing the Diamond 12.3 speakers. If you do fancy auditioning an alternative, Fyne Audio's F302i would be the right place to start.
Read the full Wharfedale Diamond 12.3 review
The best budget desktop speakers
We loved the first Ruark Audio MR1 desktop speakers with Bluetooth when they emerged in 2013, and as they entered the second-generation model, our love only grew stronger. Winners in the What Hi-Fi? Awards desktop speakers category for multiple years running, they are the closest any desktop wireless speaker has come to sounding like proper hi-fi. And they're affordably priced, too.
That's high praise indeed, but one listen and you'll see what we're talking about. The soundstage is gloriously spacious, giving each instrument enough room to breathe, and the sound is bathed in rich detail and fluid dynamics. Their timing is also a highlight. Put them in any room, and they will immediately add character along with some brilliant sonics. The Ruarks breathe new life into whatever music you play through them.
With their retro wood-and-grey styling, these Ruark Audio speakers will look at home on almost any surface, too. Quite simply, these are superb speakers of their type.
Read the full Ruark Audio MR1 Mk2 review
The best budget powered speakers
It’s possible to spend upwards of £1000 on a pair of powered speakers, but if you’re operating on a more modest budget Elac’s Debut ConneX DCB41 is a compact, great-sounding system at a fraction of the cost.
All the amplification is built into one master speaker, with a supplied cable to connect it to its passive sibling. There are no native streaming capabilities onboard, but you do get aptX Bluetooth for wirelessly connecting to a phone or laptop, with wired inputs including a pair of stereo RCAs, USB, optical and HDMI. There’s even a built-in moving magnet phono stage.
Each speaker is equipped with a 10cm mid/bass unit and a 19mm soft dome tweeter, so while they won’t quite reach party volumes, the overall performance is clear, balanced and insightful, with plenty of detail and control. The digital inputs offer the best sound, and the phono stage is only really good enough for occasional use, but there are no significant areas of weakness.
These are speakers that fade into the background, leaving the music to take the limelight.
Read the full Elac Debut ConneX DCB41 review
How to choose the best budget hi-fi speakers for you
So, we're here to find a bargain - these are affordable speakers after all - so you've already settled on a budget, which is a good first decision. Pick your upper limit and stick to it otherwise you'll never make a decision.
But what else should you be considering before you settle on a pair of speakers? We suggest measuring your room or the area for your system, at least roughly, so you can narrow you search to speakers that are the right size and not too large for the space.
Then, decide whether you want bookshelf or standmount speakers. As a general rule of thumb, bigger speakers tend to be capable of delivering higher volumes, better dynamics and more bass.
Passive, active or powered? Passive speakers require a separate amplifier. Powered and active speakers have integrated amplification, so you don't need an external amp. As a rule, more boxes means better sound, though the appeal of integrated units is convenience. Separates are also easier to upgrade one step at a time.
Want more advice? Check out our guide on how to choose the right speakers and get the best sound.
How we test hi-fi speakers
We have state-of-the-art testing facilities in London and Reading, where our team of experienced, in-house reviewers test all of the speakers we review.
What Hi-Fi? is all about comparative testing, listening to one pair of speakers up against its benchmarked rival in the same price range, to figure out exactly how they differ and how each speaker performs – and which speaker is best at its price point. To ensure we give you the best buying advice, we keep our favourite five-star and class-leading products in our stockrooms so we can always benchmark new products to ones we know and love.
We are always impartial and do our best to make sure we're hearing every product - including budget speakers - at their very best. So we'll use different partnering products, experiment with speaker positioning in the room, try plenty of different genres of music to give the speakers a workout, and give them plenty of listening time (and time to run in).
All review verdicts are agreed upon by the team as a whole rather than an individual reviewer, to eliminate any personal preference and to make sure we're being as thorough as possible. There's no input from PR companies or our sales team when it comes to the verdict, with What Hi-Fi? having decades of delivering honest, unbiased reviews.
You can read more about how we test and review products on What Hi-Fi? here.
MORE:
