Best budget/mid price system for badly recorded rock
2 replies [Last post]
Captain Destructo
Captain Destructo's picture
I listen to a lot of badly recorded rock/punk from the 70's and 80's (think the misfits)  and am wondering what brands and combinations thereof  would be most suitable for this kind of thing.  I can't empahasize enough just how wretched the sound quality of a lot of the albums really is  - not that it should matter to the music.  Obviosly I'd like to avoid a particularly 'hi-fi' sound, but on the other hand don't want something dull, woolly and boring either. I'm not really into listening to recordings, so is it actually worth spending a considerable amount of money if your taste in music is a little.... unsophisticated?  Perhaps a low cost receiver with a  budget cdp and speakers would do just as well, but I'm not sure.
 (I don't mean to offend but it seems that a majority of hi-fi enthusiasts are people in their 40's or older who tend to like mostely well recorded jazz or classical, vocal, opera etc)
gregory
gregory's picture
Re: Best budget/mid price system for badly recorded rock
hello captain,i'm in my 40's and still listen to the sex pistols the stranglers 23 skidoo and a host of other punk alt music and jazz, rock,classical not to mention silly pop song's and your right it's the music that matters but a well balanced system will bring out more of the music that matters.not knowing your budget i would check out the usual suspects,richer sounds and superfi you can pick up something for around £300.00 that should do the trick.brands to look at are cambridge,pioneer,rotel,mission,acoustic energy,mordaunt short.good luck,gregory.
Captain Destructo
the budget is about  900 pounds ($3000 NZD), more if I thought it would be worth it. So NAD, Rotel, Marantz? Combinations?  For eg would the new marantz CD6002 go well with the Rotel RA-04?
