Best budget Integrated Amplifier
21 replies [Last post]
lippo
lippo's picture
Hi there im looking to buy my first intergrated amplifier for around £250
My favorite two are
  • Marantz PM6003
  • Creek A50ir
Does any one have any advice on these amplifiers,
 I know the creek is alot older than the marantz so is a new budget amplifier better than an older bargain creek amp???
Does any1 have any other suggestions?
Many thanks Mark
__________________
My setup Marantz PM6003 - Sony bdp-s570 - Arcam Rdac - chord crimson plus - QED siver anniversary - Monitor audio Bx2
John Duncan
John Duncan's picture
Online
Re: Best budget Integrated Amplifier
I'd take the Creek, no contest (provided you don't need any of the functionality that the Marantz offers which the Creek does not, such as tone controls, phono stage out of the box, blue lights...). And yes, you can get very good value second hand - my old Primare cost me £315, and was much better than anything you could buy new at that price...
__________________
CA StreamMagic 6  |  CA 751BD  |  CA 651A  |  PMC DB1i
Moderator. mail: john.duncan.whf at the mail of g dot com
matthewpiano
matthewpiano's picture
Personally I'd take the Marantz. The PM6003 is a superb piece of kit - endlessly involving and dynamic with a superbly natural sound, particularly if partnered with a pair of Dali or Mordaunt-Short speakers.
__________________
Rega RP3/Elys 2, Roksan K2 CDS, Squeezebox Touch, Denon PMA720AE, Q Acoustics 2020i, Sennhesier HD595, Beyer-Dynamic DT770PRO, Chord Crimson/Chord Rumour 2
SteveR750
SteveR750's picture
For £250 I'd search for a good cond used NAD C352. You'll have the electronic equivalent of a faithful labrador, and some change to buy a tump of new CDs.
__________________
JRiver MC17 -> Cambridge Audio DACmagic+ -> Roksan Caspian M2 -> ProAc D18
plastic penguin
plastic penguin's picture
lippo:
My favorite two are
  • Marantz PM6003
  • Creek A50ir
Many thanks Mark
Another vote for Creek. Also Arcam DIVA A65 Plus is very good value for £150 or A85 £300.
Regards new amps definitely Rotel RA-04SE. The Marantz Matthewpiano mention are very good but, for me, Rotel all the way.
__________________
Leema Pulse MKII-S; Naim CD5i MKII; Denon TU-260L MKII; MA RS6 speakers; Pro-ject Xpression 1; loads of different cables...
Formerly known as plastic penguin
Hedgehog
Hedgehog's picture
+1 for the Arcam A85, and you could even get it a bit cheaper if I remember correctly what I saw on Ebay today.
 Hedgehog
__________________
MacBook Pro & MF V-DAC • Arcam CD 73 • Arcam A85 • Proac Response 1SC • Chord Cables
vinod_david
vinod_david's picture
From your choice, I'd lean more on the 6003. And, outside your choice, its the CA 650A.
__________________
Setup I: Denon DM38DAB → Q Acoustic 2020i
Setup II: PC → FLAC → J.River MC16 [asio4all] → Furutech Formula 2 → Musical Fidelity V-DAC II → Chord Crimson Plus [VEE] → PrimAcoustic Recoil Stabilizer RX5 → Focal CMS40 [Active]
PC Config: Intel Core i5 2310 | Windows 7 64 bit | Gigabyte Mobo | Corsair Vengeance 4 GB x 2 | SeaSonic S12II 430W | CM Elite 311+ | Seagate 1 TB + FreeAgent GoFlex Drive 500 GB
Old Setup: Cambridge Audio 640C V2 → Cambridge Audio 640A V2 → Squeezebox Classic → Merlin Mozart → Van Damme Studio Blue → Monitor Audio RS6
scene
scene's picture
IF it was just down to the two you'd chosen, I'd also go with the 6003.
However, casting the net wider, I'd definitely plump for the A85...
__________________
Hi Fi: Arcam A85, DV88 (CD only), Project Debut II, AE Compact-1. AV: Arcam AVR250, DV79, Sony BDP-S760, Monitor Audio Silver 8i, RS-LCR, RXFX, Sonos ZP90, Pioneer KRP500A. 2nd AV: Pioneer SX-SWR2, Dell Zino HD, KEF KHT2005.2 eggs, Sonos ZP90. That Cable HDMI, Chord Crimsons and Sonos ZPS5s everywhere & a spare Yamaha RXV-667!
d_a_n1979
d_a_n1979's picture
For me it has to be one of the main 3 - NAD C326BEE, Marantz PM6003 or the Rotel RA04
If you wanted to save some money then have a look on eBay and the likes for the NAD C320BEE. Superb amp and won numerous awards
the record spot
the record spot's picture
There's pros and cons for both - though just wondering why you narrowed down to the two you did?
No quibbles with Marantz from me; great brand, great pedigree, great sound, but I like that presentation. Of the others, there's a bunch up to £250 you can choose from. I'd also add the Harman Kardon HK980 amplifier. If you can forgive thae, frankly, daft volume knob (cosmetic flim flam that lights up when the amp's on to give a kind of moonglow effect, or something), I heard the much bigger (physically and design-wise) HK990 and can only report good things. If the 980 is half the amp, for £250 you won't go wrong.
If you opt for the used route, there's the usual pros and cons - better kit for less money, as JD mentioned, you'd be hard pressed to clap hands on a new Primare amp for much less than a £1k sum, never mind a whisker over £300.
My tips - Technics SU-V6: hugely underrated, massive build, very very clean sounding amp and very easy sound to live with.
NAD - C370 or the earlier 319 which both picked up good reviews, especially the former (I think Stereophile still have an online one you can check out).
Lastly, there's my one which is simply the best amp I've heard - Sansui's AU-717. Internal build to die for. Mine cost me £200 delivered, allow £75-100 for a good service to replace corroded capacitors (mine had a load of smaller ones needing replacing, but it still sounded good beforehand!) and you're in for £300 or so. Difficulty is i) finding one and ii) accepting - as you have to with any older bit of kit - the need for a bit more TLC. Once all that's done though, you've got a class leader.
I tried out a Harman Kardon HK990 and a Leema Pulse a few weeks ago while my 717 was in for repair, had the Pulse at home for a week and though both were very good, excellent in fact, when the Sansui came back and was now fully fixed, there was only one winner. The effortless ease that comes with any music you play with one of these is hard to describe, you just forget there's any gear there at all and enjoy the music, but enjoy it in a way that makes it sound more real and more lifelike.
Whatever you decide on though, enjoy it and happy hunting!
__________________
Onkyo TX-8050 / Tannoy Revolution DC4 / Marantz SA7001-KI / Apple TV 3 / Sony PS3 320Gb / Denon DVD-3930
gregory
gregory's picture
£69.00 Cambridge A1. no contest.
Fraz1
Fraz1's picture
Richer sounds are doing the nad C355 just now for £250. Nothing comes close at that money imo.You can also get a 5 year warranty and a level of guts and drive in an amp that is hard to match.That's what i would get.
__________________
Nad C542 cd, Nad C352 amp,Epos M5 speakers on Custom design stands,Chord company chorus interconnect,DNM precision speaker cable.
johnnyblue
johnnyblue's picture
I think the Nad's £299.95
Blackdawn
Blackdawn's picture
and they only have a few left, apparently.
__________________
HiFi- Cambridge Audio 340C- Pioneer A30- Boston Acoustics A26 speakers. Denon FM/AM. Pure DAB.
Marantz CD6004 - Beyerdynamic DT250
the record spot
johnnyblue:
If you show them the WHF ad, you get it for the £249 price.
__________________
Fraz1
Fraz1's picture
There is an ad in WHF that has it for £250.As record spot says, if you take it in you get it for £250 and at that price there is nothing to touch that amp.
__________________
