67 posts / 0 new
Last post
Geo_scars's picture
Last seen: 3 years 4 months ago
best bassy speakers
As the title says
Best bassy speakers
ID.
ID.'s picture
Last seen: 1 week 1 day ago
RE: best bassy speakers
Subwoofers
Geo_scars's picture
Well that's obvious I mean normal free speakers that aren't sub's because most subwoofers are coonected via pre outs etc
ID.
ID.'s picture
I'm taking the mickey. You ask such a general open question and give no details, so that is the best answer for you.
OK, I found that these
http://www.bowers-wilkins.com/Speakers/Home_Audio/800_Series_Diamond/800-Diamond.html
have excellent bass.
Or how about you tell us your budget and what amp you plan to pair them with so that people can suggest something suitable. (you weren't expecting other forum members to find all of your threads so far and deduce your thoughts from them, were you?).
Geo_scars's picture
To be honest I'm looking for
To be honest I'm looking for a good set up. I know hardly anything about amps speakers CD changers mini disc etc so my budget isn't here as I have no idea how much a set up will cost that isn't shit. The reason for such an open question is cause I don't know sub categories for each part of equipment I'd need so far I'm starting from stracth and need the advice of someone who knows a good system setup and can tell me how much to spend
kingsap's picture
Last seen: 1 year 2 months ago
if budget is of no contraints.....i reckon the bang olufsen beolab 9 have awesome bass!!!!
lindsayt's picture
Last seen: 5 hours 44 min ago
Huge sealed boxes with very large bass cone area through multiple 12" or 15" cones or single 18" to 30" cones. Likely to be 3 way or 4 or 5 way. Bass cones must be good quality: light weight but rigid. Variable density cones are good too.
Needs to be combined with good to great midrange and treble drivers. It's no good if the bass is great if the midrange and treble doesn't inspire you to listen to them.
Solid state amplification for the bass tends to be better than valved. The reverse applies to the midrange. A source with good bass is needed too - which can be a weak point of some vinyl sources. Digital sources should be fine for bass.
And the room and speaker positioning within the room should avoid excessive echoes for cleanest bass.
CnoEvil's picture
Last seen: 6 hours 29 min ago
RE: To be honest I'm looking for
Geo_scars wrote:
To be honest I'm looking for a good set up. I know hardly anything about amps speakers CD changers mini disc etc so my budget isn't here as I have no idea how much a set up will cost that isn't shit. The reason for such an open question is cause I don't know sub categories for each part of equipment I'd need so far I'm starting from scratch and need the advice of someone who knows a good system setup and can tell me how much to spend
You need to set the spending limit, as you can spend the same on hifi, as cars, or even a house.
To answer your initial question - Dynaudio and Kef R Series.......though you need to consider the amp at the same time, as the partnership between the two is crucial.
"We should no more let numbers define audio quality than we should let chemical analysis be the arbiter of fine wines."  Nelson Pass
the record spot's picture
Last seen: 1 year 10 months ago
You can get excellent bass from small speakers, not just larger ones.  You need to have a budget in mind, whether you want to buy just new or would consider secondhand, what your room is like if it can accommodate bigger speakers, what you need your stereo to do, play LPs, CDs, stream radio / movies / Spotify, if you have any Apple gear so you might want to use Airplay, or DLNA instead....etc, etc, etc!
mattmeer's picture
Last seen: 3 years 3 months ago
Pmc speakers, with their transmission line design, best bass i ever heard from a smaller/normal sized speaker, including floorstanders. Never heard really big expensive floorstanders though, but the bass created by the transmission line of pmc speakers is very punchy, similar to a sub. Maybe not as deep as a seperate sub, but certainly very punchy and dynamic.
and pmc makes transmission line standmount speakers aswell as floorstanders
davedotco's picture
Last seen: 8 hours 21 min ago
This........
The Behringer iNuke Boom.
The biggest, baddest docking system in the world, problem solved.
TrevC's picture
Last seen: 1 month 2 weeks ago
Wilson Benesch Arcs have astonishingly good bass for a small stand mounter. Far from cheap though, and need a powerful amp.
davedotco's picture
The best speakers I have
The best speakers I have heard, at anything close to sensible money, with the ability to deliver 'club' like power and bass are the Mackie HR824s.
Recent price rises have pushed then up to about £1400 but they remain outstanding value. The in room response will get down below 40hz but it is their power and punch in the two octaves above this that is really impressive.
For me the HR824s are too much for use at home, the smaller, cheaper HR624s will do me fine, but if you really want bass that can be heard from space, the HR824s are the way to go.
Bear in mind these are active speakers with 150 + 100 watts of power onboard so you could drive them from a computer soundcard or even a docked iPod.
richutd18's picture
Last seen: 2 years 1 month ago
Guru Junior's are great small
Guru Junior's are great small stand mounts and can be placed close to a wall. They have very good bass considering their size.
Crocodile's picture
Last seen: 3 months 6 days ago
I suspect most of these suggestions are going to be a little wide of the mark given that one of the OP's other threads was wanting (& I paraphrase) an "everything louder than everything else" system for an overall budget of £100-200.
OP, can I suggest that you stop opening numerous threads & just concentrate on one? Just add posts to the others diverting to that one.
Then perhaps we can get to the bottom of exactly what it is you want & how much you're prepared to spend to achieve it.
You've previously said you want it louder than normal domestic. For what purpose, occasional parties, constant high volume, filling a large space?
You seem pre-occupied with bass & subs. Why? That says to me that you're not really interested in hifi but rather something akin to the thump thump thump of the passing Corsa with an exhaust the diameter of a dustbin. Not a problem if that is what  you want but you won't get it from hifi. You may need to look more towards a small DJ type setup.
What are you proposing to use as a souce? CD, iPod, PC, other?
Now please don't take this the wrong way. I'm not trying to be offensive nor sniffy about your requirements but if you're to receive meaningful responses, the forum really needs to understand your requirements.
lindsayt's picture
For a budget of £100 to £200,
For a budget of £100 to £200, the best bassy speakers would be something like Goodmans Magisters. Combined with a decent classic amp, such as an A&R A60 and he'd have decent bass, with good enough midrange and treble and the ability to play very loud when he wanted. Such a set-up would be frimly in hi-fi territory too. Not the best sounding system ever, but the sort of system that would leave you thinking "Why pay more when you get this sort of sound for so little?"
Pages
Log in to post comments
