Best £1000 integrated amplifier?
2 replies [Last post]
wolfie01902
wolfie01902's picture
Hi all,
Want to buy a new integrated amplifier, have about £1000 to spend. Listen mainly to rock based music with the odd bit of classical thrown in. Currently have a Creek A50, which is ok, but think I can do better. Would also like the facility to add Pre or Power amp later. Any ideas?
Jez
Clare Newsome
Clare Newsome's picture
Re: Best "1000 integrated amplifier?
Hi Jez,
I'd suggest Cyrus is the way to go.
You could either buy the Cyrus 8VS2 integrated (£800) - our current Award winner at your price point - or go for a pre/power from the off, but (as the Cyrus' are so small) ones that'll take up the same shelf space as a standard-size integrated.
The Cyrus Pre Vs2 preamp (£600) and Cyrus 6 power amp (£400) are five-star performers that'd give your music a boost.
And of course you can add PSX-R power supplies (£400) to either the integrated or pre/power amps as a further upgrade as/when you need.
__________________
Group PR Manager - Computers Unlimited;
Former Group Editor of What Hi-Fi? Sound and Vision and Whathifi.com
Twitter: @ClareNewsome
wolfie01902
Hi Clare, Thanks for replying, will certainly road test The Cyrus Pre Vs2 preamp and Cyrus 6 power amp, just about fits my current budget, well let you know how I get on. Jez
