Bad room acoustics.
11 replies [Last post]
kusum65
kusum65's picture
 Ive come to the realization that however much money i spend on kit im never going to hi_fi heaven because i have a lousy room. In fact according to the russ andrews website i should invest in headphones or move. I live in hope i dont have to go to such extreme measures !
My problem is bass resonance , lots of it, and im convinced its coming from my 601 speakers. Ive tried pavement slabs,new  stands { dreadnoughts, did tighten the base up significantly}  and a new rug but my room still sounds boomy with  a double bass for example or shrill with mid bass vocals if that sort of makes sense. Oh yeah , the reason Mr Andrews thinks i should give up my favourite hobby {why do i keep typing his name Meyers} is the fact i have suspended wooden floors and partition wall behind me.
Has anyone been in a similar psition and experimented with decoupling products , isolation platforms etc . Any advice would be appreciated . If you dont help me i might buy an i pod or something.
silly
silly's picture
Re: Bad room acoustics.
The solution is easy,Russ Andrews is 101% wrong.Isolation won't do a thing,nor will cables.What you need is room treatment.Your room is live,reflective.....it needs taming.
You can do this by room treatments,the easiest way is more furniture,curtains,and a thicker carpet,or you can buy or make specialist treatments,for your problem you need to find what freq is causing the problem and treat it.
Remember you will need broadband absorbtion to trap as many freqs as possible,bass traps in all 4 corners of the room,absorbtion at all your first reflection points,you can use specialist fire proof foam,or make your own using rockwall,or fibreglass at about 10cm thick,60cm W X 120 length.
place them at first reflection points and behind your speakers,then hear the difference.
hifikrazy
hifikrazy's picture
Yup, agree. Isolation may firm up the bass a little, but it ain't gonna remove the boom. And yes, it's acoustic treatment that you need. Just take note that the usual eggtray foam stuff is too thin to have any effect on the bass - they're useful to absorb echo though. The bass traps have to be much thicker and denser to work.
Check these out:
http://www.hsfacoustics.com/studiopacks.htm
If all else fails, take drastic measures and plug the bass ports with the foam bungs but personally, I feel that the sound is very constrained with the bungs in place.
kusum65
kusum65's picture
 Thanks for the help, cheered me up no end. On the subject of room reflection,how do you work out where your weak points are?
silly
silly's picture
Have a friend with a mirror stand to one side, when you see the tweeters in the mirror, that's the first reflection. Do the same for both speakers.
zappa 100
zappa 100's picture
 In our previous house, the lounge where the hifi usually resided had a suspended floor over a cellar and the back dining room had a solid concrete floor.
If the missus was away for the day,i used  to move the cd,amp and speakers into the dining room  and for a few hours at least i had the sort of defined,solid deep  bass we all aspire to!
I suppose the concrete reflected the bass back into the room whereas the  wooden floor allowed it through into the cellar never to return.
Now,i'm not suggesting you fill the void under your floor  with cement but what it does prove is that the only way to audition speakers ,is in your own room with all  the alcoves,bay windows,chimney breasts and suspended floors etc that you never see in your dealers perfect dem room!
__________________
Project x pack, Trichord Dino. Marantz PM 6300, Arcam CD72, Neat Petite SX, Cables by Cambridge Audio and Mogami, Partington Stands
hifikrazy
hifikrazy's picture
Even with your system placed in a symmetrical room, it's often the luck of the draw whether you end up with too much bass or too little bass. If I had to choose, I would go for the first one because it's still possible to treat. However, I have experienced a room with bass cancellation issues that is just impossible to get any decent bass in, no matter where I placed the speakers or moved the listening position. Absolutely frustrating!
silly
silly's picture
You can actually treat a room that has a bass suckout using bass traps, people think that a bass traps just traps too much bass,whereas it actually can also help keep bass in the room, i'd rather has too little than too much, as bass I guess is the sound that annoys most neighbors.
ranjeetrain
ranjeetrain's picture
 I'd also go for sealed designs. Bass reflex, no no.
Thaiman
Thaiman's picture
follow the link below, many found the unit does help a great deal:
http://www.enjoythemusic.com/magazine/equipment/0705/behringerultracurve...
__________________
TW Raven AC - Soundsmith SG-410 - MSB 202 - Gershman Acoustics Black Swan - Audioquest K9
silly
silly's picture
I dont recommend a Behringer,it's just a plaster, it can only measure from where the microphone is placed, so it will only treat the listening position, not the room, it can't cure many problems that can found in room, most people who buy these products tend to sell them quite soon afterwards.
Thaiman
Thaiman's picture
If you are using it between transport and DAC it will become one truly amazing equipment! Don't forget that it's only cost £200! The build in DAC is good enough to rival the like of Cambridge Audio 640c. Very complicated but when get it right it's simply superb. (for the budget end)
__________________
