B & W 683 Speaker matching Amp
8 replies [Last post]
kaushik_mitra17
kaushik_mitra17's picture
Hi You all I have B & W 683 speaker. I am looking for my speaker's matching amp. Pls help me out. help, I`m sinking
MUSICRAFT
MUSICRAFT's picture
RE: B & W 683 Speaker matching Amp
Hi kaushik
What amp, source component/s and cabling are you using?
What do you generally listen to?
Are there any facailities such as tone controls, headphone socket, etc. which you would like the amplifier to feature?
The size of your room?
Your general listening level?
Budget?
What type of presentation are you looking from the new amp and for the system to reproduce?
All the best
Rick @ Musicraft
__________________
Musicraft (Derby), Specialist Hi-Fi/AV & Multimedia Dealer
good accurate audio monitoring and good sound reproduction to all Smile
kaushik_mitra17
I using Ecoss M45 Bi-ware Speaker cable, VDH The First Ultimate Interconnect. My room size is 11/9 fit. I usialy listen Instrumental Disk.
ISAC69
ISAC69's picture
What's your budget ?
__________________
Hi Fi : ROKSAN KANDY K2 - PROAC STUDIO 140 MK2  - ROTEL RCD1520 -  interconnects : Tellurium Q Black - Chord Chorus2
AV : YAMAHA RXV767 - WHARFEDALE 9.CM [C] / 10.2 [SR] / INFINITY PRIMUS PS8 [SUB]
MUSICRAFT
MUSICRAFT's picture
Hi kaushik_mitra17
Thanks for your reply.
What amp are you currently using?
What source component/s will you be using?
All the best
Rick @ Musicraft
__________________
kaushik_mitra17
Thanks for your reply. Currently I using Marantz SA7001 CD Player as a source and matching amp looking for. Generly I listening Instrumental , Vocal, basically soft track. My current system is Quad 22L Floor Standing Speaker, Quad 606 Power and 66 Pre amplifier, Philips CD 624 CD Player, Audio Note DAC ONE 1x Signeture and Musical Fedelity x-10D Buffer. Now I buy B & W 683 Speaker and Marantz SA7001 CD Player. Right now I looking for a matching Amplifier for my B & W 683 Speaker. Now pls suggest me best matching amp. Thanks.
MUSICRAFT
MUSICRAFT's picture
Hi kaushik
I take it that the SA7001 & 683's are to replace your current system. If so, then I'll recommend that you use your Quad per/power as these amplifiers should match well with the SA7001/683 and also suit the genre of music that you listen to.
All the best
Rick @ Musicraft
__________________
kaushik_mitra17
Thanks for your advice. But I need a separate system for separate Flat. Then what kind of  amp you advice with my SA7001 and 683.
SupertoMMo
SupertoMMo's picture
You existing system is very good. May I ask what your budget is? I used to own the Marantz PM7001 and it was quite a decent amp, however I thought that pairing the two together might result in overall slow pace on the system (which to me, is quite a signature on Marantz)
Moon I-1 and above the line should sound nice as well. I had the I.5 for a while and though it is not a very powerfull amp, it worked quite well with my then Spendor SA-1.
__________________
My System   Memoirs of an Audioholic:My Hall of Fame
Source: Linn Majik DS-I Integrated Amplifier: Accuphase E407 Speakers: Totem Arro Cables and Accessories: Copper Colour Interconnect, Nordost Heimdall Speaker, Shunyata Researh Venom 1, Totem Beak
Auditioning: Linn Majik 140/NHT Classic 3
This and That: iPhone 4, iPad2, B&W P5, Twonky Media on Mac mini early 09
