14 posts / 0 new
Last post
ruivasco's picture
Last seen: 3 years 2 months ago
Atlas equator superior
ruivasco's picture
RE: Atlas equator superior
Well, I don´t know what happened to my post. Anyway, the question is I have the Atlas IC Equator MKII. Should I buy the new MKIII with the new plugs, or is it a side move?Better the Hyper?
CnoEvil's picture
Last seen: 5 days 10 hours ago
Can you borrow one from a dealer and try it?.......What will it cost you to change?
"We should no more let numbers define audio quality than we should let chemical analysis be the arbiter of fine wines."  Nelson Pass
ruivasco's picture
No, I can´t. I have to buy it and sell the mine
ruivasco's picture
Anyone who heard both may help?It is the Equator MK II and the MK III, not the Superior
CnoEvil's picture
I suspect there will be an improvement, so it all depends on the cost to change, as to whether it's worth the effort......you will be lucky to find anyone who has directly compared the two, but you never know.
You are also likely be told that any possible difference is in your imagination.
ruivasco's picture
CnoEvil wrote:
I suspect there will be an improvement, so it all depends on the cost to change, as to whether it's worth the effort.......
I just want to trade because I bought a better amplifier, so I guess a better IC would improve the sound.
CnoEvil's picture
IME It likely will, but there are no guarantees.....and putting a value on any possible improvement is personal.
I'm afraid I can't be more definite than that.
BenLaw's picture
Last seen: 1 year 11 months ago
Why?
I am the danger.
CnoEvil's picture
BenLaw wrote:
Why?
....because (imo) improved connections can make a difference......but we've been here before, so not going there again (since you won't persuade me that I'm not hearing what I'm hearing; and I won't persuade you that I'm right).  Smile
BenLaw's picture
I wasn't planning on 'going there'  Blum 3 - it seems neither of us has heard the product to comment personally. It just seemed a very 'trusting' conclusion to draw  Wink
Anyway, hopefully it's taken your mind off rendering for a post or two  Wink
I am the danger.
CnoEvil's picture
They have though (not that you can trust Hifi mags) :shifty: :
http://www.atlascables.com/assets/files/pdfs-reviews/HFC_Extras_October2012.pdf
Blum 3
TubularTechnician's picture
Last seen: 2 years 2 months ago
I've got the MKIII coming from DAC to amp. Why ? Good reviews and was in the price bracket my chosen kit dealer told me to pick from. Sadly I've missed out on HiFi for many years so can't compare it to any other cable at all. Except 5 blind tests with a beach towel covering my 16 year old daughter and all my kit , while she swapped the supplied RCA's with the Atlas. I picked the Atlas every time. No contest. Einstien and Hawkin could turn up and tell me I'm hearing things , expectation bias blah blah blah, but I'd tell them the same. I know the kit sounded better with the atlas.
Not much point in posting about it as I can't help the OP out re MKII v MKIII. Other than to say that it feels good quality, looks good quality but whether or not it is making a positive or negative difference as opposed to MKII or any similar priced connect I couldn't say. Others can argue about does it / doesn't it .
But sometimes just thinking that it does, even if it probably doesn't, can make you happy and keep your interest going. Mrs Tech bought a frock for a wedding the other day. She thinks it makes her bum look smaller. It doesn't but she thinks it does and therefore is wery happy with her purchase. So I'd wager is the owner of the small shop she gave the £200 to. Same applies to HiFi cables imo. Money stays in the HiFi world, more manufacturers and retailers survive and we get better products no ?
ruivasco's picture
Blum 3
Thank you for these review
Log in to post comments
