ATC scm19 / PMC ds-001 monoblocks - a good match?
13 replies [Last post]
krolikgena
krolikgena's picture
The DS-001, a compact, highly adaptable, 200W cutting edge, audiophile Class D, power amplifier with world beating audio performance
Your opinions?
__________________
PMC TB2S-AII
Benchmark Dac2
Cyrus CD8X
Tellurium Q black XLR
Primacoustic London 10
David@FrankHarvey
David@FrankHarvey's picture
Online
RE: ATC scm19 / PMC ds-001 monoblocks - a good match?
"World beating" sounds like you're taking snippets from the press brochure Smile
I happen to like Class D amplification. I'm not saying it leaves Class A/B standing as you have to take every comparison on an individual basis, but it does have benefits. For their size, the DS001's are cracking little amps, and ideal for those that need something pretty discreet. Of course, for those that aren't after the discreet aspect, they do have competition at around £1200 per pair.
For home cinema users, they can be mounted on their sides in a purpose built 'rack' and placed on an equipment stand shelf. Five wide takes up about the same amount of space as a normal multi-channel power amplifier, so there's no space saving aspect for home theatre users, but they can be added to move from five channels to seven, or to nine.
__________________
David @Frank Harvey Hi-Fi, Coventry
Mitsubishi HC7000 / Oppo BDP103 / Audiolab 8200AP / Rotel RMB1575 / kick ass speaker system
krolikgena
Sure, it's a quote from their site )
David, how well they would perform with the atc's?
__________________
PMC TB2S-AII
Benchmark Dac2
Cyrus CD8X
David@FrankHarvey
Online
They should work fine with them, as I tend to find Class D amplification has a bit more grip and control over speakers. If their power rating is true, then they should have no problem driving them, even to high levels.
__________________
Excitable Boy
Excitable Boy's picture
RE: ATC scm19
Hi Krolikgena,
Surely you've been on this forum long enough to realise that ATC's work wonderfully well with every sort and combination of equipment ever made, in every shape and size of room, and with every type of music ??  (Just don't spend too much on cables !)  Wink
MUSICRAFT
MUSICRAFT's picture
RE: ATC scm19
Excitable Boy wrote:
Hi Krolikgena,
Hi E B
Within the last year it looks like ATC's are now not the only ones shhh  (particularly where amplification is concerned) as now almost all if not all amplifiers ever produced (and most if not all new amplifiers in the years ahead) are now/will be at a minimum of being 'fine'. With the latter there seems like no limit what is spent on speaker cables either Beer
Anyway, something else for you to quote elsewhere Smile
All the best
Rick @ Musicraft
__________________
Musicraft (Derby), Specialist Hi-Fi/AV & Multimedia Dealer
good accurate audio monitoring and good sound reproduction to all Smile
MUSICRAFT
MUSICRAFT's picture
Your opinions?
Hi krolikgena
Power wise the DS-001 should have more then enough quality of power and i would say that the DS-001 has also got enough quantity of power (for many rooms) to be paired with ATC's SCM19 monitors. SCM19 monitors have a benign load that does not go below 5.5 ohms. Anyway if possible try and listen to this combination to see if the reproduction suits you.
Btw, if possible try and also see SCM19's mid/bass drive units in the flesh (away from the cabinets). Worth the time and effort as you get to see ATC's massively engineered and built SLMT drive unit. Real beauty lies within :)  You can read more about SLMT here  http://www.atcloudspeakers.co.uk/downloads/CompanyProfile.pdf
Fwiw, i feel that SCM19 monitors are probably the VFM passive bookshelf designs currently available on the market regardless of price.
All the best
Rick @ Musicraft
__________________
David@FrankHarvey
Online
Listening to Suzuki, by Tosca
One thing I didn't mention, is that whether you actually like this particular combination is a matter of taste. As the DS001's are quite neutral with no real characteristics of their own (a little like Bryston), you may feel them a little too neutral to pair with the SCM19's. I find ATC's own amplification a little on the smooth side, which I'm assuming is a tone that ATC have chosen to perfectly partner their speakers. The DS001's you might find the opposite. It is something only you can decide with a demo Smile
__________________
hoopsontoast
hoopsontoast's picture
Online
Another alternative:
http://www.bkelec.com/HiFi/ClassD/ClassD.htm
180w Monoblock for £200/ea
Mentions the Flying Mole/PMC amp in the bumpf.
__________________
Sony DVP-S9000ES | DIY SET / Eagle SA100 | DIY Speakers / Eclipse TD-508 / Keesonic Kolt
krolikgena
Thanks all for your replies.. i have arranged a demo of ds-001 at local pmc dealer next week party time!
__________________
PMC TB2S-AII
Benchmark Dac2
Cyrus CD8X
MUSICRAFT
MUSICRAFT's picture
Hi krolikgena
Nice one  Smile
All the best
Rick @ Musicraft
__________________
krolikgena
just want to update,
Now i have a pair of PMC TB2S-AII which are a passive monitors with attached to the back ds-001 mono amps. and they sound simply sublime Smile
connected to the my new Benchmark Dac2 they provide a kind of total transparency and precision that i was looking for. a sense of not listening to just a good loudspeakers, but a huge soundfield coming at me.. that never happened at many hi-fi auditions that i've been to.
and this flat responce is so addictive... want to hear music more and more!
__________________
PMC TB2S-AII
Benchmark Dac2
Cyrus CD8X
BenLaw
BenLaw's picture
Online
What are your thoughts on the benchmark dac 2? Have you heard the dac 1 to make a comparison?
__________________
HiFi   /   A/V   /   Bedroom
krolikgena
yes, i've had a dac1 hdr before and replaced it with the dac2. it's really hard to say regarding sound quality as i didn't have them side by side.. overall i feel it's even more transparent and revealing than the hdr
__________________
PMC TB2S-AII
Benchmark Dac2
Cyrus CD8X
