Atc scm 11 or pmc fb1+ any help?
Hi
I want to buy one of those speakers but I dont know which one will be good
My amp is roksan kandy , rdac arcam .
My room is 18m2 wih open kitchen on the right side .
Hifi system is on the longer wall. So my sweet spot is arround 40cm from back wall
Music thats i listen to is Rock , jazz, a lot of vocal music.
Any help ?
You're talking about two very different animals. Contrary to Cno, the Kandy ( if it's the K2) should be warm enough to deal with ATCs.
With a Kandy, however, I'd look at PMC GB1s rather than FBs, otherwise as Cno has suggested.
Nicely making my point about subjective opinion on what goes well together.
I had monitor audio rx8 and they were to bright , i just sold dynaudio focus 220 they had to much bass .
And i have Roksan kandy 2. I like good bass but not to much , i love deep soundstage not wide.
I live in dublin and the audio shops are not random here , i have only Cloney audio there is System audio speakers and B&W so iam not intrestem about them
I can have good price for used pcm fb1+ 770£ and atc new one for 830 £ but iam affraid of bass in atc is only 58hz :(
thanks for help
ATC can be perceived by some as quite a clinical sounding speaker. I have owned the bigger ATC scm19 and just couldn't live with them, they just sounded too harsh. The Kandy and PMC's are a good combination though, my previous amp was the K2 partnered with the PMC GB1i's.
Hope this helps.
Absolutely: When I heard the K2 and ATCs at 'The Towers' they didn't come across as bright. I think the bigger issue hear is whether the OP plays his music low-medium levels or requires to shake the walls. If it's the latter ATC should be just the ticket, otherwise PMC or Dynaudios (the latter of the two is an afterthought*).
* The Dyns need at least two to three foot gap from the wall.
That could explain a lot, as I believe the WHF rooms are acoustically damped.
Having owned Dynaudio, PMC, and ATC, I feel like I can weigh in here. The OPs concerns about the ATC SCM11s being bass light are legit. They are great speakers, but they need a sub for my taste. I would go with the PMCs hands down. I think they are exactly what the OP is looking for. More bass than the ATCs, but not as much as the Dyns. Also, the bass is less full than with Dyns. The ATCs will be too bass light.
Jaxwired is about right. Maybe a better comparison would be ATC SCM19 and PMC. The 19s have a larger cabinets which will give deeper bass, and will be more flexible than the Dyns with positioning.
That's true, but apart from a leather sofa there's no other soft furnishings. So although the walls are damped - different bits of kit going down one side of the wall - the room could be echoey.
oki so pmc fb1+ will be better
they have more bass then atc 11 yes but not to more then dynaudio focus 220
If the Walls were damped, the kit along the side wouldn't make it echoey, but maybe even help break up the sound...but you were there, and I'm only guessing.
The kit on the side wall wouldn't make it echoey. The room is larger than the average living room, and with the sofa, it was still quite sparse.
As I understand it the listening room is acoustically treated, so the lack of furniture is irrelevant. I'm sure the powers that be could tell us definitively.
I disagree with some of the comments re the 11s: true they don't go as low as a speaker with a port or transmission line, which go artifically low. But I never felt I was missing out on bass and where they excel is in bass speed and definition, so a bass connoisseur who appreciates texture may like them. I also listened to them mostly at low volume levels with no problem.
Finally, I wouldn't say there's any 'combination' problem as such: you will hear your roksan and arcam electronics. If you like that, then ATC should be good. If you want to change something, perhaps look elsewhere.
I would encourage you to demo in any event, as you can tell ATC is a 'marmite' speaker and my opinion or anyone else's isn't going to reach the right decision for you.
Good luck and let us know how you get on
I think I've said it before, but it isn't really the speaker that is "marmite", but the situation in which you put it.
Feed it the right diet of amp and source and it reflects them honestly. IMO It should come with a warning - "Match with care", 'cause it gives you your system (and music) warts and all.
The only way you will know for sure is to listen for yourself.
For my taste the Kandy + the ATCs would be too bright and forward....I would prefer the PMC, or even better Proac, Spendor or Sonus Faber.....but that's the thing about taste, mine doesn't really matter (to you).
"Everything has been said before, but since nobody listens we have to keep going back and beginning all over again." André Gide
