29 posts / 0 new
Last post
ebentjerodt's picture
Last seen: 2 years 1 week ago
ATC CSM 50 ACTIVE CARZY IDEA PLASE YOUR ADVICE!!??
I was just reading a review of the ATC SCM 50 active
http://www.stereomojo.com/ATC%20SCM50ASLT%20SPEAKER%20REVIEW/ATCSCM50ASLTSPEAKERREVIEW.htm
and they say if you have a balanced CDP with volumen control which is the case of my Olive 06 you can connected directly to de speakers.
if this is the case I can get the ATC 50 active just giving my Gryphon and ATC 19 without extra money.  I am aware that I will not getting the best of the speakers connecting it directly to the Olive but I am quite sure it should sound better (and bigger) than my current combination and this will give me some time to save more money and buy a top class pre amp later   or is to stupid what I am saying??
Eduardo
chebby's picture
Last seen: 23 hours 9 min ago
RE: ATC CSM 50 ACTIVE CARZY IDEA PLASE YOUR ADVICE!!??
You can't just plug in a source to passive speakers.
Proper active ATC speakers (like the SCM50 ASL) will have electronic crossovers feeding a dedicated amplifier for each driver. (And they will cost a fortune which is another clue Smile )
If I have misunderstood your question, then I am sorry but it wasn't entirely clear.
Mind you, that article you linked to is as clear as mud! It refers to the ATC SCM50 ASLs as 'active', 'powered' and 'self-powered'. Most confusing. Refer to ATC's own website where they say...
"Each drive unit in the active model has its own dedicated and individually matched MOS-FET amplifier, while the 234mm/9″ bass driver incorporates ATC’s unique Super Linear Magnet technology. Our active crossover network consists of a wide band-width, electronically balanced input stage with high common mode rejection and very low distortion."
iPad Mini 3 • iPhone 6 • B&W P3 • Mac Mini • Apple TV3 • Quad Vena • Pro-ject Tuner Box S • Audio-Note AX-Two
Hi Chebby,
this is what they say;
The input is fully balanced allowing the system to be driven from a suitable remote source via long cables (up to 50M). In fact, the only way to connect the speakers to a source is via fully balanced XLR’s. If you have a balanced CD player with volume control, you can eliminate the need for preamp altogether if it is your only source.
get my idea?
kr
Eduardo
MattSPL's picture
Last seen: 1 year 7 months ago
He's talking about using the olive with its volume control direct into ATC scm50asl's, and being able to swap his gryphon + scm19's for the 50's.
chebby's picture
No I don't get it yet. I know you can plug a source (with volume control) into a set of active speakers but you said...
ebentjerodt wrote:
... if this is the case I can get the ATC 50 active just giving my Gryphon and ATC 19 without extra money.
... I don't understand that bit about the ATC19s. They are passive speakers. The Gryphon is a dual mono power amp.
exact!!!
chebby's picture
Oh right!
Gotcha.
Sorry it's late. (And I had to unpick the post a bit.)
Chebby,
it is as Matt say.  I will give my ATC 19 and gryphon for the 50 active. if I can conect the olive direct to the 50 y will aybe be able to do the up garde wihtout extra money and buy later a good Gryphn pre amp.
my concern if ist the olive direct to the 50 will be good enought for the moment.
kr
Eduardo
chebby's picture
There is a possibility it might sound better without another bunch of electronics (like a pre-amp) sitting between  it and the speakers. Less is more (sometimes).
AlmaataKZ's picture
Last seen: 3 weeks 2 days ago
You need to check the output level on the olive and input sensitivity of the atcs. I cold not find the info on the olive on their web site or in the manual. Atcs input level is adjustable. It should work but try to find out olive's output spec.. You can also use fixed or variable passive attenuatirs if necessary. http://www.pinkfishmedia.net/forum/showthread.php?t=132457
http://wiki.slimdevices.com/index.php/Connecting_directly_to_a_power_amplifier
AlmaataKZ's picture
Found it - olive balanced out is 4V, so you will be fine without a preamp, but you need an attenuator.
read the slimdevices wiki link above, it explains everything well.
chebby's picture
Output (unbalanced) 2V RMS
Output (balanced)     4V RMS
http://www.olive.us/products/music_servers/olive6hd/specs.html
MattSPL's picture
chebby wrote:
Oh right!
Gotcha.
no worries Smile
Overdose's picture
Last seen: 2 years 2 months ago
Eduardo
If your Olive has volume control, then it can indeed be plugged straight into the ATCs and control them without needing a preamp.
Great!!! thank you very much for your help  AlmaataKZ!
and waht do you think about the idea?  should I go for the actives?
Eduardo
AlmaataKZ's picture
I think you should try fact 8 and atcs actives side by side. You liked fact 8 so my guess is when you hear the atcs you will think that they have no bass. In fact, what you will hear is less mid bass harmonics, i.e. cleaner bass. I hope if you listen to both of them for some tome you will see that they are much more accurate, much more powerful and much more dynamic. If you buy the atcs you will qyickly get used to cleaner bass and soon will not be able to stand anything less.
So, the best thing to do is try.
You are about to spend a lot of money, so you need to be sure. Do not rush. Take as long as you want, enjoy the process of understNding what you want and choosing it!
Pages
Log in to post comments
