atanakata - your speakers .....
4 replies [Last post]
Thompsonuxb
Thompsonuxb's picture
Are'nt your speakers too close together, I was just reading through another thread and checked out your system pic - Speakers that size surely need to be further apart to work their magic and clear of your electronics too.
I know space is a premium. I don't have pics but my speakers are about 2m apart at the opposite end of the room to my electronics (floorstanders)
I'm actually curious how many people here have their speakers set up in the "classical" stereo format/position?
AJ20011
AJ20011's picture
RE: atanakata - your speakers .....
Thompsonuxb wrote:
Are'nt your speakers too close together, I was just reading through another thread and checked out your system pic - Speakers that size surely need to be further apart to work their magic and clear of your electronics too. I know space is a premium. I don't have pics but my speakers are about 2m apart at the opposite end of the room to my electronics (floorstanders) I'm actually curious how many people here have their speakers set up in the "classical" stereo format/position?
Same setup as you, speakers one side, systems other side, speakers are about 4 meters apart.
__________________
King of Vintage
HiFi #1: Luxman C-02 Pre-Amp | Luxman M-02 Power Amp | Luxman T-02 Tuner | Sansui CD-M12 (12 Disk CD Player) | Onkyo Integra EQ-35 Graphic Equalizer | Monitor Audio BX2 Speakers
HiFi #2: AR (Acoustic Research) C-06 Pre-Amp | AR P-10 Amp | AR RD-06 Tape Deck | AR CD-06 CD Player | AR T-04 Tuner | B&W CDM1-SE Speakers
atanakata
atanakata's picture
Morning, Thompsonuxb...
Yes, my speakers are too close ( 160 cm ) together  to my liking...From my listening position ( 250-270 cm ) , I could definitely do with another 1 m or so in between them ... Then I would have that equilateral triangle between speakers and listener, that is best for stereo...But I simply do not have the space. We`re having a lounge-dinning in one room and it is just not possible. As you can see from the photos on the left is the gateway to the kitchen and on the right is the door to the hall... It will be this way till we change the flat, and we`re working on that now Smile
However , I am using my system equally  for AV too, and in that Set-Up the speakers should be 0.5 ft -2 ft away from the sides of the screen - in which case I`ve ticked that box perfectly Smile But , yes indeed, they are too close together for stereo...
__________________
Samsung UE46D6530 > QED Performance HDMI > Denon AVR-1909 > Chord Active Silver HDMI > Denon BDP 2010 > Leema Linx 1 Interconnect > Leema Pulse Stereo Amp. > ProAc Signature Black Speaker Cable > Beresford TC-7220 2-way Audio Switch > Atlas Hyper 1.5 Speaker Cable > M.Short Mezzo 6,Mezzo 5 and Mezzo 1 on Atacama Nexus 6i > Wharfedale SW150 Sub
My Set-Up
RobinKidderminster
RobinKidderminster's picture
Online
Hya. I have just recieved my m-s system. Mezzo 8 & sub rather than 6. Do they improve with run-in? Wow what an improvement. Pix & comments later after some tweaking. Suggest pulling sofa away from wall a few cms. May experiment with room acoustics too. Does the centre need room to breath? Mine is in a cabinet.Cheers.
__________________
Mordaunt Short Mezzo System C - 8,5,1,9.Yamaha V2065. SonyS570. Panasonic 42in., Sky HD 1TB. Garrard 86SB. PF30. Wii. WDTV Live. Harmony One. STAX300. QED cabling. Galaxy Tab 10.1
System Photos - http://s1051.photobucket.com/user/robinkidderminster/library/?sort=3&page=1
 Base trap Project -  http://www.whathifi.com/forum/home-cinema/corner-base-trap-completed-project?page=1
atanakata
atanakata's picture
RobinKidderminster wrote:
Hya. I have just recieved my m-s system. Mezzo 8 & sub rather than 6. Do they improve with run-in? Wow what an improvement. Pix & comments later after some tweaking. Suggest pulling sofa away from wall a few cms. May experiment with room acoustics too. Does the center need room to breath? Mine is in a cabinet.Cheers.
Hiya, Robin,
First of all - congrats. on your new speaker system  beauty, eh  That is a massive sound you`ve acquired ... From what I can see on the photos you`ve got enough room between the fronts - which is very important for the stereo , indeed... But you would have to pull them away from the walls , that`s for sure - fronts, and rears too... They sound much better  if you give them at least 50 cm from the wall ... You`ll notice that right away with the fronts, not so much with the rears as in your case they`ll be satellites  ( Mezzo 1 , right ? ) .
As for the center speaker - as you can see the box is closed - so normally it shouldn`t be a problem placing in the cabinet, but with the Mezzo 5 , still having that Aspirated Tweeter....well I don`t know. I`ve never experimented with mine, but to me, that tweeter needs as much air as possible to breathe ... Then you get that open and clear sound out of it ... But I might be wrong, give it a try...
About the run-in. Yes, my Mezzo 6 did improve after a while , the sound overall became much smoother and and easy on the ear - with one word " polished "  But I didn`t do the 72 hours ( facing-each-other-from-close-distance ) run-in as the booklet suggest. I was just leaving the stereo ON  ( using Repeat mode ) while I was working for about a week ... But the real improvement was when I hooked them up to the Leema Pulse Amp - I was blown away , literally ...
I am very curious about the Mezzo 9 ? It will be interesting to hear you thoughts on it ,after a while of course Smile
__________________
My Set-Up
