Are my speakers good enough
4 replies [Last post]
jamesbrown838
jamesbrown838's picture
Hi
I have a naim cd5i, a placette passive volume controller, arcam p35 and arcam p90 bi-amping monitor audio RS silver 6.
Are these speakers good enough or can they be improved upon. Sometimes think system can be a bit bright. Dont care if they are bookshelf or  floorstanding, max spend £1000
Thaiman
Thaiman's picture
Re: Are my speakers good enough
I found monitor audio tweeters very bright!
£1000 will get you.....
Link 1
Link2
Link3
All should be a good match for your system imo. Yes
__________________
TW Raven AC - Soundsmith SG-410 - MSB 202 - Gershman Acoustics Black Swan - Audioquest K9
jamesbrown838
Thanks for that are any of these fussy about placement as I use a typical living room with limited space, Speakers are 6 ft apart and 30cms from wall. Can't part them anymore but could pull out another 10 - 15 cm if needed. Also any bookshelf speakers to recommend
Thaiman
Thaiman's picture
The DALI and Neat are not too fussy, in fact closed to wall placement can bring out more bass, Focal how ever do like to be place in to the room.
The best standmount pair under a grand for me is this little beauty.
__________________
jamesbrown838
Thanks for that, I would like maybe the Pro Ac . I don't use a centre speaker for home cinema just monitor audio rs1 for the rear so all should be O.K  I think. Do the Pro ACs need much room or are they easy placed .
I used the rs1s as fronts for music before and in some ways I prefer the standmounts sound.
Thanks again
