Arcam or onkyo
12 replies [Last post]
aversaurus
aversaurus's picture
Looks like I'm in the market for a change of amplifier. So the ones I'm looking at are Arcam alpha 8 pre and power amp combination. Which I would hope would give me a warm smooth sound or a onkyo a 9050. Looks like it's going to be a 5 star amp and I do have the tx8050 and the onkyo c7070 so I do like the onkyo sound. So to very different amplifier s.what do you think? Any other amps you would consider pros. And cons
__________________
sansui au 717 sansui au417 rega Mira arcaydis dm1  onkyo cd 7070 onkyo tx8050
BigH
BigH's picture
Online
RE: Arcam or onkyo
What is your budget?
matthewpiano
matthewpiano's picture
RE: Arcam or onkyo
Review of the A-9050 in the amplifier supertest in the new issue of WHFS&V, out today.  Tested against Denon PMA720AE, Marantz PM6004, something from Edwards Audio, and the award winning Rotel RA10.
__________________
Rega RP3/Elys 2, Roksan K2 CDS, Squeezebox Touch, Denon PMA720AE, Q Acoustics 2020i, Sennhesier HD595, Beyer-Dynamic DT770PRO, Chord Crimson/Chord Rumour 2
aversaurus
RE: Arcam or onkyo
budget of around £350 but will go second hand
__________________
DIB
DIB's picture
RE: Arcam or onkyo
You will get a nice Creek Evo 2 amp secondhand off Ebay for that sort of budget. One on there now.
__________________
Speakers: Epos Elan 30
altruistic.lemon
altruistic.lemon's picture
RE: Arcam or onkyo
What's wrong with your current amps?
aversaurus
RE: Arcam or onkyo
its time for a change and for a second system build
__________________
aversaurus
RE: Arcam or onkyo
i have just read the onkyo review in whf lean sound so thats out.so maybe a rega brio r.they seem to have a warm sound anyone on here use one as there main amp?
__________________
plastic penguin
plastic penguin's picture
aversaurus wrote: Looks like
The TX-8050, according to some owners, betters a lot of sub-£1000 integrated amps. Whether that's true or not I couldn't say, but I think, if sound quality is the goal, you'll need to stretch your budget a lot further: Look at Creek Evo2 or other amp of similar quality.
__________________
Leema Pulse MKII-S; Naim CD5i MKII; Denon TU-260L MKII; MA RS6 speakers; Pro-ject Xpression 1; loads of different cables...
Formerly known as plastic penguin
the record spot
the record spot's picture
RE: aversaurus wrote:Looks like
Yip, and I'd be one of them.  Delivers a massive amount in a small package.  I'd take it over the new budget Onkyo range too.  100wpc, four digital inputs, Spotify onboard, can take a power amp and a subwoofer, quite a neutral sound, so it's straight down to your speakers and CD player or whatever.  Fabulous for the money.
__________________
Onkyo TX-8050 / Tannoy Revolution DC4 / Marantz SA7001-KI / Apple TV 3 / Sony PS3 320Gb / Denon DVD-3930
Shanka
Shanka's picture
RE: Arcam or onkyo
I bought a s/hand alpha 9 last year and love the sound of it, feels warm, not laid back, can listen to it for hours and often do as I have it in a room with my computer.It has plenty of power and produces plenty of air in the sound and is certainly not bright or harsh as the B&W speakers I use with have a slightly bright top end so in my opinion they work well together.
I have not heard the Alpha 8/power combo but if it is much the same as the 9 I would be happy, the amp only cost me £130 w/o phono stage.
I personally find Creek amps a little to laid back and 'dry' sounding but that is only my view,
Good luck with your choice, do try and hear first of course.
__________________
Roksan Caspian M2 cd/amp ; Proac Studio 140 Mk 2
Ariston RD11s SME 111 AT95e Rega Fono MiniA2D Arcam Alpha 9 B&W CDM1NT
JoelSim
JoelSim's picture
RE: Arcam or onkyo
Arcam A85/P85. Tight on £350 though.
__________________
Unison Research CDE, Leema Tucana 2, Kudos C2 and some cables.
csq2
csq2's picture
RE: Arcam or onkyo
I actually just upgraded  to the Onkyo A-9070 from a Rega Brio 3. The bass on the Onkyo is amazing: tight, controlled, and extremely detailed. Vocals are very clean and have a degree of warmth, unlike the A-9050. Actually it has the eloquent sound of my Rega, but with better bass and extended highs. I was surprised by how similar it sounded compared to my Rega Brio 3, but everything sounded tighter and more defined with the A-9070. The A-9050 is excellent for the money, but there is no info display which is a shame and the onboard dac is of inferior quality. Rotel RA-10 is also excellent for the money, but it really needs a remote.
Here's my list of recommended amps:
1. Nuforce DDA-100
2. Pioneer A-70
3. Vincent SV-400
__________________
USB->Hegel HD2->Coaxial->Onkyo A-9070->Klipsch RF-62 II
