6 posts / 0 new
Last post
millgate1's picture
Last seen: 3 years 5 months ago
Arcam A19 and NAD CD or Audio Lab 8200 dilema
Hi I am a new member and am just about to purchase a new hi fi separates set up and would appreciate your view on the following.
I already have sonos and the connect and will be linking up the new hi fi to it. I am running with the Arcam A19 and I will also get my collection of CD’s onto flac / lossless and run back off a NAS drive but I still want the facility to play CD’s but don’t want to pay a fortune for a CD player.
I have come to the conclusion to run a reasonable CD through a good quality DAC but am undecided on the following 2 basic options.
A NAD C516BEE CD or should I spend the extra on the NAD C546BEE CD and run this through an Arcam iRDAC
OR... splash out on an audiolab 8200C and dump the iRDAC as this already has a very competent DAC with more or less the same inputs excluding the BT line that is.
Does anyone have any experience of the NAD’s run through the Arcam A 19 and their compatibility.
I have to say I heard the Audiolab 8200 with A19 and BX5’s and it sounded pretty good to me?
BigH's picture
Last seen: 2 months 6 days ago
RE: Arcam A19 and NAD CD or Audio Lab 8200 dilema
From what I have read about NAD cdp lately I would look elsewhere. Many modern cdp do not seem to last long, I would be inclined to buy an old cdp like a Marantz 63 KI which you can get for under £100 or a slightly newer one like the 67 SE.
As for Audiolab 8200 you may want to read this: http://www.whathifi.com/Review/Audiolab-8200CD/user-reviews
Listen to the music, not the hifi.
Lo Fi's picture
I would go for the Audio lab I have one with the Arc am A19 and it makes a great combo.
I have not had any of the issues given and I think you will find that most problems were a while ago.
p_m_brown's picture
Last seen: 10 months 3 weeks ago
Hi, welcome to the forum. I
I would always suggest listening to equipment before committing to buying but if you have a blueray player, just hook that up to the dac. Afterall, the dac is what you hear, not the disc spinner!
Clearaudio, Naim, Audio Physics
millgate1's picture
Thanks for your comments i have had a look at the 8200 neg comments but think i am still reasonably convinced that is a good match for the A19. Certainly sounds so much better than the NAD.
Blue ray player is a good idea but i want to keep the Lounge  for sound (TV is banished from this room)and keep the TV in the Family room. Otherwise a good shout.
Unless someone can recommend a better CD match for the A19 i think i am going to run with the Audiolab 8200.
Thanks again for your helpful comments.
Lo Fi's picture
At the price point you will not find a better match IMO as I said I have both and am very satisfied. As a matter of interest I have MA RX6 speakers in my set up.
Log in to post comments
