"Another one bites the dust"...
12 replies [Last post]
Hughes123
Hughes123's picture
One of my Missions just blew! I was listening at reasonable levels with my Arcam A32 and all of a sudden this vibrating sound comes from the left speaker every time it has to move for low bass. Ironically, the song was Madonna's "Material Girl" on the CD "Like a Virgin" (1984 copy)!
What should I do, give them back to Mission as they are under warranty or give them to my local dealer, when I bought them off him for £30 in an open-box sale?
Is it my fault though? I don't play them that loud and I'm always careful with them. My 100wpc Arcam gets to about -17db usually. Is this too loud? Am I asking too much from them?
andyb190
andyb190's picture
Re: "Another one bites the dust"...
Take 'em back but open box sales sometimes have diff conditions of purchase.
At least he'll know the best way to sort, or replace them. Might even give you a deal on a better set ........might not though !
Big Chris
Big Chris's picture
If I played early Madonna through my system, I'd full expect it to commit Hari Kari..... Either that or they'd get up off their stands and beat me to death.........And I'd deserve it....
Wink
__________________
Hi-Fi: Arcam A85, P85, CD192. B&W 602S3, PV1, Grado SR125, Atlas Titan, Hyper 2.0.
A/V: Sony KDL-V40A12U, BDP-S760, Humax Youview, Onkyo TX-SR875, B&W MT30 7.1, QED HDMI-P, S.A XT
Tannoyite
Tannoyite's picture
I don't think it's your fault. There's probably something loose inside (the spider or something). Unless the store warned you there is no warranty, they should take care of this. After all, once they confirm this failure was not due to misuse, Mission will send them the spare parts for free.
Hughes123
Hughes123's picture
Thanks alot everyone! I'm going to take them back tommorrow and ask for them to be repaired.
Nothing wrong with a lil' bit o' early Madonna!
In the mean time, I thought I would try something a bit different; I connected my parent's little micro-JVC to my vintage JVC amp with some JVC speakers and then used the built in SEA EQ on my vintage JVC amp to keep a balanced and neutral frequency response in the dining room. The result is seriously impressive!
TNTTNT
TNTTNT's picture
My understanding is how long have you had them is a factor in your favour. If less less than 6 months then the law assumes the fault was present in the goods at purchase. If longer then I am sure you can claim that the seller has an obligation to supply goods that are fit for purpose. If they blew under normal listening conditions, then they are not fit for purpose.
The seller may insist that you have to go to Mission. This is normally utter rot. Your contract is with the seller, not Mission, and he has to return them to manufacturer, and absorb courier charges.
I bought a garmin sat nav unit which went wrong after 3 weeks. The vendor told me to go to garmin. When I said my purchase contract was with him and not garmin, a new unit came in a couple of days.
If the dealer is not helpful, ring Trading Standards for advice. Household insurers often provide a legal advice line, so this may be an option.
Hughes123
Hughes123's picture
I would have said I have had them for only 3 months! I doubt he'll complain; I've spent over £2k there, so I'm sure he wants to keep me as a happy customer!
TNTTNT
TNTTNT's picture
I find sales people and shop keepers can be very unpredictable when things go wrong. That said you are absolutely right. It is better to start of positively minded and expect the best result to start with, rather than think of worst case immediately.>>
I wish you the best, and hope you have a happy and satisfactory result.>>
Hughes123
Hughes123's picture
My days, if the Missions going weren't enough, my other JVC amp is on its last legs! Now, after about an hour of being warm (more like boiling hot) the background noise increases significantly and makes a sound like a test tone on speakers (is it blue noise or something?) and then alot of distortion kicks in when music is played!
Is there anyone who can fix solid-state amps? It's all integrated circuitry aswell! I wouldn't like to see my JVC go, but I'm scared it might cause a fire or something as whenever I touch it (it's got a metal case), it pops from the static and sometimes the right channel stops and you have to bang the amp ontop for it to work again!
Torres09
Torres09's picture
Im with Big Chris on this one.............playing early Madonna tut, tut, tut
May i suggest you bring them back to the dealer and Open Your Heart and Express Yourself, tell him you were just getting Into The Groove playing some Borderline  tunes.................
If that fails just take a Holiday....................
Gwyndy
Gwyndy's picture
Hi
The information that you need to use is here.
http://www.consumerdirect.gov.uk/after_you_buy/know-your-rights/electrical/
http://www.consumerdirect.gov.uk/after_you_buy/making-complaint/template...
please bear in mind that they may end up saying you damaged them by playing them too loud, although I think they would have to get an independent report to prove this.
friendly1_uk
friendly1_uk's picture
Hughes123:
sounds like its just a loose connection. Shouldn't cost much. Any friends good with stuff? a poke about with a dry wooden spoon usually finds the problem. Thats a job for someone who at least owns a soldering iron though. Its hardly safe.
welshboy
welshboy's picture
Must be all that over-compressed music you like! Devil
