13 posts / 0 new
Last post
plycrsk's picture
Last seen: 3 years 6 months ago
Amplifier ideas? secondhand?
Hi All,
Have decided on rega rp1 as my starter turntable. Probably going to pair up with q acoustics 2020i speakers. Really have no idea about an amplifier though, had a look at a couple of Rotel RA-04/SE's on ebay, but not 100% sure this would be a good idea.
Budget is probably £200 for amp, but would ideally like to spend £100-£150. secondhand i feel this is definitely doable
Sam
plycrsk's picture
RE: Amplifier ideas? secondhand?
looking at http://www.whathifi.com/review/cambridge-audio-azur-340a-se/specs also
tech specs say MM phono in - NO. does this mean i need to buy a phono preamp as well?
it says integrated on manufacturer website, which i thought meant it had a built in preamp.
am i getting confused between a preamp and a phono stage?
thank you all.
tomlinscote's picture
Last seen: 2 years 6 months ago
a pre-amp and a phono amp are not the same things, a pre-amp sets the volume tone and input for passing the signal to the power section of an integrated amp whereas a phono amp converts the phono level RIAA signal into a line level singal ready for the pre-amp to deal with. If the CA amp does not have a phono input then you will need a phono stage inbetween the TT and the Integrated amp.
Tommo
matthewpiano's picture
Last seen: 3 weeks 4 days ago
Personally I'd go for the Rotel out of those two.  Rotel make tremendous affordable amps and the RA-04SE is a great example with a good phono stage and better overall quality than the Cambridge 340.
You might also wish to look at used Arcam amps - A65+, A85, Alpha 8R, Alpha 9.  All have excellent phono stages and, although not always the most instantly impressive amps they really can satisfy on a long listening session.  The best integrated phono stage I've had was the one on my A65+.
Rega RP3/Elys2/TT PSU- Denon DCD720ae - Pioneer A400  -  Wharfedale Diamond 220 - Atlas Equator 2.0 - Beyer DT-770PRO - Mission stands
davidpr's picture
Last seen: 1 year 7 months ago
Have a look at a new Onkyo A9030 from Richer Sounds at £169. The phono stage is not good but at this price the amp is a good buy.
plycrsk's picture
Thanks all. Looking at rotel ra-04se, marantz pm6003/4, arcam a65+ at the moment. seeing what i can find on ebay.
Will take a look at the Onkyo, thank you.
Sam
Hi-FiOutlaw's picture
Last seen: 5 days 20 hours ago
At the mentioned amps above I just add two, a Rega Brio 3 if you can get your hands in one don't think back!
And a NAD they do have very nice phono stage, I speak for my old but in good shape 3020i ( just £40 on ebay) but with your budget you can buy some thing more recent.
:cheers:
Rega RP6/Goldring Elite MC>Clearaudio Basic Plus
Synology NAS>Auralic Vega>Pathos Classic One MKIII>Dynaudio X12
plycrsk's picture
like the look of the 3020i actually. as i'm starting out, if i could help it i'd rather spend £50 than £200 on an amp.
it's quite easy to get carried away and go from spending £500 on a system to £900.
MakkaPakka's picture
Last seen: 1 year 1 month ago
Actually the A85 doesn't have a phono stage - it was an optional extra. That said, it's probably outside the poster's budget so unlikely to get caught out.
BigH's picture
Last seen: 1 month 3 days ago
Always a difficult one, spend less and then upgrade sooner or spend more and  keep for longer. MAybe visit a second hand dealer and hear some of this gear? My advise is upgrade in big long steps rather lots of smaller shorter ones.
Listen to the music, not the hifi.
matt49's picture
Last seen: 1 month 2 weeks ago
Are you within reach of London? If so you might be interested in dropping me an e-mail at matthew.g.bell AT gmail.com.
Matt
iQ Speakers's picture
Last seen: 2 months 4 days ago
I've just replaced my RA04 I can now appreciate what a really good amp it is.
You won't be dissapointed.
Nord Acoustics, Nord Hypex Amplifiers, Abrahamsen Audio and IPL Acoustic Speakers. (boggit): Sonos - Cambridge CXN - Nord NC500 Power Amp, Abrahamsen V20 UP - Various IPL Acoustics Speakers.
plycrsk's picture
Probably going to run a rega rp1, q acoustics 2020i and looking at an arcam a65+,
very new to this, but are there any obvious concerns with this setup?
Thank you all,
Sam
Log in to post comments
