Amplifier for q acoustics 2050i
1 reply [Last post]
Snkrishna
Snkrishna's picture
Hi all,
i was looking for a good amplifier with AirPlay and network connectivity for the q acoustics 2050i speakers.
wish to choose an amplifier that has the possibility to cater to a home theater upgrade, even though initially I will initially use for stereo playback only.
was thinking abut either the marantz sr6007 or the denon avr2113.
Any feedback?
regards, Krishna
gurjitsidhu
gurjitsidhu's picture
RE: Amplifier for q acoustics 2050i
I have the Yamaha RX673 and its great with the 2050i speakers! I have them bi-wired and the amp delivers enought power.
also that amp has a very good airplay. i would recommend that combo- it ticks all your boxes plus the yamaha av amps are known to have good output for stereo music too. also the q acoustics will allow you to buy the 5.1 in the future so you have a full system. this is what im planning on doing Wink
__________________
Yamaha CDS300 CDP ----> Rega DAC-----> Yamaha AS500 Amp-----> B&W 684
Airport Express ------> Rega DAC-----etc..
