7 posts / 0 new
Last post
Hamster's picture
Last seen: 3 years 8 months ago
amp,cd player to match monitor audio rx8
hi,id like some advice on cambridge audio 851 a & 851  c combined with my monitor aido rx8,would these form a good combo or what else could,and ideas would be appreciated.
Ben K.'s picture
Last seen: 3 years 4 months ago
RE: amp,cd player to match monitor audio rx8
I'm very happy with my arcam a38/cd37 combo so I would advise to try it if budget allows. I have also heard roksan k2 cd/amp combo with my speakers which also sounds very good and comes in a lot cheaper if your budget is tighter. I would also try roksan caspian m2 cd/amp combo if budget allows.
Ben K.'s picture
During my search it was suggested that creek and musical fidelity are a good match so these should be looked at if possible.
I haven't heard the Cambridge audio you refer to although I have been told they are forward sounding and so may not be the best match with the metal tweeter. However it's always best to judge for yourself where possible.
CnoEvil's picture
Last seen: 1 week 4 days ago
I agree with Ben K....maybe adding Sugden and Unison Research Unico range as well.
"We should no more let numbers define audio quality than we should let chemical analysis be the arbiter of fine wines."  Nelson Pass
plastic penguin's picture
Last seen: 9 hours 22 min ago
I personally would avoid Cambridge gear with MA Silver.  From experience that would give an over-egged sound.A warmer or smoother amp/source such as Creek, Arcam, One of the Nads, MF would give a more agreeable sound, yet this is all really egg-pendent on the room acoustics layed.
Leema Pulse; Arcam CD73; PMC TB2i; Pro-ject Xpression with a ClearAudio cart; Denon TU260 MKII
Hamster's picture
thanx for the feedback guys,unfortunately i cant audition any of these where i sta so i have to make a choice and go for it,maybe the roksan kandy as i did here this is a good match.
kevinJ's picture
Last seen: 1 year 1 day ago
I'd stay away from the Cambridge electronics, they would make the RX really bright.
Have a look/listen at some Marantz components. I find they partner great with the RX8.
Log in to post comments
