AMP power for KEF LS50
22 replies [Last post]
L00k_C
L00k_C's picture
Merry Christmas to everyone..
I would like to know what is the minumum or more appropriate amplifier power tha the KEF LS50's need to be driven smoothly.
I am between a Creek 5350 (125w at 8ohms) and CYPRUS 6XPS (just 40w at 8 ohms)....... I usually listen to my music at high levels......
Is it always the more powerful the better to drive them?
CnoEvil
CnoEvil's picture
RE: AMP power for KEF LS50
Merry Christmas to you as well.
That is a little simplistic. If an amp can produce lots of current, then the Watt rating is less important. Look out for its power into 8 Ohms and into 4 Ohms, or even 2 Ohms. An amp with a really good power supply will double it's power as impedance halves.....though Valve amps usually don't work like this.
__________________
"Everything has been said before, but since nobody listens we have to keep going back and beginning all over again."  André Gide
Crossie
Crossie's picture
Kef LS50's are relatively small standmounters with a low 85dB sensitivity. If you want loud then perhaps a larger more sensitive speaker may be better. Both amps are very good, the Creek has plenty of omph but lacks the detail of the Cyrus. Lots of choices at this price level, take your time, listen to lots of options.
__________________
Toshiba Netbook J River, Cyrus Pre XPdQX with PSX-R, 4 x Cyrus Mono X's, Wilmslow Phoenix with Bass Extenders.
zarathz
zarathz's picture
Hi All,
I am looking to buy a new set-up in the next week or so, and the Kef LS50's sound pretty impressive.  The fellow at the store recommended the Brio-R as a good integrated receiver, but I'm not sure if it will be powerful enough to fully bring out the Kefs.  I'm rather new to the audiophile scene.  Anybody have any thoughts?  Oh, I should say that moeny is an issue, but I could stump for a pricier amp if that was needed.
therecruiter
therecruiter's picture
IMO the BrioR has more than enough power to run the KEF LS50's but the KEF R100s are more better suited as they seem to manage the Brio R's power better.
To get the best out of the LS50's then more powerful amps would be needed for normal listening levels and some loud levels; the BrioR suffices.
It's really horses for courses so get some demoing done and see what you think suits what best Smile
__________________
Living room: iTunes to ATV 2 (via AirPlay) to Cyrus 8 DAC with KEF LS50 speakers - Tellurium Q Blue cables
Spare room: Marantz CR603, AirPlay, Monitor Audio RX2's - Chord Odyssey 2 cables
Alears
Alears's picture
Like Crossie says there is plenty of choice out there. I would also consider the Roksan amps to drive LS50's, either the K2 or Caspian.
__________________
Origin Live Aurora Gold+Illustrious Mk2 arm+Zyx R100-02/Stello CDT200+Stello DA220 Dac/Tom Evans Groove Anniversary/Tom Evans Vibe Preamp/Linear A power amp/Acoustic Zen Adagios/ Chord cables
jjbomber
jjbomber's picture
I heard the LS50s powered by a Heed Obelisk amp, rated at 35wpc. I was 25 feet away and it was plenty loud enough. I would suggest that you listen to the Creek, Cyrus and whatever else is on your list. You will be surprised.
The more powerful is better but the watts figures are normally a joke anyway. Until they bring in a universal way of measuring, the figures are just misleading.
zarathz
zarathz's picture
Thanks for the advice.  I'll listen to a few amps and figure out what pairing works well.  While I normally listen to classical and jazz, I also delve into the deep house, so a sub may be necessary.  Will report back what the system ends up looking like!
L00k_C
L00k_C's picture
I have heard the LS50's with the Creek 5350 and it sounded really nice...
No problem with power as well.
MrHat
MrHat's picture
Since this thread is already there, and I had the same question, but with a particular amp in mind:
would the Marantz pm7004 be suited to drive the LS50s? Would this work in a somewhat larger room? (say 28 sqm?)
From what I understand Marantz and Kef go well together, and the pm7004 is powerful enough, but I'm not an expert..
BigH
BigH's picture
Do you have the Kefs already?
I have read an article about amps and it says really you need at least 100W for domestic listening even at low volumes because otherwise the sounds will be clipped. If you don't have your speakers yet I would seriously consider hearing some active speakers first before deciding.
The_Lhc
The_Lhc's picture
First I've heard of it, sounds like utter hogwash to me.
__________________
No signature worth mentioning...
BigH
BigH's picture
Well its by someone who makes hifi maybe you should read it. Unless you have a low powered expensive amp.
The_Lhc
The_Lhc's picture
Give us an idea of where you read it and I might...
__________________
Craig M.
Craig M.'s picture
According to the Crown amplifier power calculator, if you are sat 3 metres from 85db speakers, and want to to listen at 85db with the ability to hear 15db peaks without clipping, you need 285 watts.  http://www.crownaudio.com/elect-pwr-req.htm
85db is the same volume as city traffic from inside your car.  You would need 90 watts using the above example to achieve an average of 80db with 15db peaks.  80db is the same as a telephone dial tone.  http://www.gcaudio.com/resources/howtos/loudness.html
Does it seem any less like utter hogwash now?
__________________
Synology NAS + Audio Station - ATV2 - Benchmark DAC1 HDR - Event Opal
http://nwavguy.blogspot.co.uk/2012/04/what-we-hear.html
The_Lhc
The_Lhc's picture
85dB/w is a pretty low sensitivity speaker though.
That doesn't seem to match up with THX's reference level guidelines:
THX Certified Receivers reproduce studio Reference Level, 85dB SPL with 20dB of headroom.
which the same page describes as "Reference Level—it is often too loud for your neighbors."  which would seem to be quite a bit louder than city traffic from inside your car.
I've heard a THX system running at 0dB on the volume scale, I like it loud but I'd never want to listen to anything at that level.
If I'm honest, no. I have heard a lot of people mention that a "normal" listening levels most amps are putting out no more than a few watts of power though. I guess it depends on your definition of "normal" though.
__________________
