8 posts / 0 new
Last post
Dave2860's picture
Last seen: 2 years 12 months ago
Amp Help Cambridge Audio SR10
I have a Cambridge Audio SR10, and at any other volume that stupidly loud, there is a serious lack of bass.
I tested to see if it was my speakers using my dads old Denon UPA-110 and the sound is so much better. Bass is back and speakers are sounding good and full. Swap back to the Cambridge and No bass again.
Im confident the amp isn't faulty as my friend has a cambridge amplifier and he also doesn't have much bass at lower levels.
I also like how the volume is off and on full with 1 spin of the dial, on the denon and not a digital display like the CA.
So i was thinking of buying another amp. I need 2 sets of speaker outputs, and 2 inputs?
Can anbody help me?
Thanks,
Dave
ID.
ID.'s picture
Last seen: 1 week 2 days ago
RE: Amp Help Cambridge Audio SR10
Well that narrows the options down to just about most amps on the market.
Not sure that many people would have experience matching Bose speakers to other kit (I may be wrong on this point). Bose doesn't have a great rep on this forum, and neither does your Cambride Audio amp.
Maybe if you at least gave us your budget, people might be able to give an answer.
Apple Mini -> Pioneer U-05 -> Adam A7X
ATV -> NuForce Icon HDP -> Genelec 8020C
Sennheiser HD650, HD595; B&W P7; Audio Technica ATH-AD900X, ATH-A900X
ear
ear's picture
Last seen: 2 years 1 month ago
I dont have any problem with bass on my SR10.it it a bit brighter than other amps but doesn't lack bass . the speakers I have with it are the CA S30 and they have nice and powerfull bass for the size.they lack  a bit of definition on the treble deppartment. I have the amp set do bass -6, and treble +8 , just you get an idea that with that setting i still have enough bass with the speakers.
ear
ear's picture
I remember listenning to the Bose 301 with my Harman Kardon 3390 wich I also have and it certainly gives big bass sound, and when I heard it with the Bose 301 I remember thinking how it sounded so bass light.Must be something with the frequency response of those speakers.
Dave2860's picture
Hi Guys,
Looking to spend around £250,   £350 max.
The speakers are great i love them and once i crank the amp up, the walls rattle, its just when i have them at a comforable listening level, theres no bass at all.
Like i said with my dads denon amp the sounds is fantastic and full, but im looking for my own as im pretty sure he will be wanting it back now.
Ive had my eye on the marantz-pm6004, i might nip into richersounds for a quick demo after work.
thanks for the replys
richardw42's picture
Last seen: 1 week 6 days ago
There's a Denon UPA110 on eBay for £50 +10 P&P. has a 30 day warranty Smile
you may want to ASQ as that's not a uk plug in the pics.
Dave2860's picture
Thanks but i need 2x speaker outputs and 2x inputs.
anybody know if the pm6004 produces a decent amount of low end grunt?
Dave2860's picture
if it helps i prefer the design of volume MIN at 7o'clock and the volume MAX at 5'oclock?
Log in to post comments
