Airplay Sound Quality-does a wireless transport make any difference if you are not using a dac?
53 replies [Last post]
shafesk
shafesk's picture
Hello again, fellow forum members.
Having recently purchased an Apple Tv, which is connected through my dacmagic and to my speakers I found the sound quality a bit worse than when my macbook is connected to my dacmagic via optical using the same cables. The sound is a bit bright and I'm missing some tight bottom end. Anyone else have this issue? Can you also tell me that if I were to better the Apple Tv using a streamer, is it possible provided that I use the dacmagic? It is my opinion that more expensive streamers sound better simply because they use more expensive dacs. If you remove the dac from the equation I reckon a wireless streamer as a transport doesn't make that much of a difference. Thoughts and arguments absolutely welcome.
Cheers,
Shafin
__________________
Hi-fi:
Denon DNP-720AE network streamer, Mordaunt Short Mezzo 6, Cayin A-55 T, Technics-SLQ210, Denon DP-29F turntable, 540p, Dac-magic, Marantz 5004CD and 6025 Turntable, Mac ,Pure AV interconnects, QED Revelation speaker cables, QED Performance interconnects.
Head-fi:
Akg K702, Grado SR60i, UE Triple-fi, Musical Fidelity X-cans, HRT Music Streamer 2+
ifor
ifor's picture
ifor
In my experience wireless falls short of wired.  I use Airport Express where you use Apple TV and Arcam rDAC where you use the DACmagic.  When iMac and Airport Express are working wirelessly sound quality is poor.  So I have turned off WiFi on iMac and Airport Express and connected them via Ethernet and Devolo HomePlugs.  The result is excellent.
__________________
Source 1) "Inspired" Manticore Mantra turntable c/w Rega RB 301 arm, Goldring 1042 MM Cartridge, Graham Slee Reflex M phono stage, Graham Slee CuSat 50 interconnect
Source 2) Cyrus CD8 SE CD player
Source 3) iTunes (ALAC), iMac, Devolo Homeplugs, Apple TV3, Toslink, Arcam rDAC
Source 4) Technics SL-7 linear tracking turntable.
Roksan Kandy L3 amp, Spendor A5 speakers.
Other rooms: more Airport Expresses and Homeplugs with Denon AV system and Denon Mini system.
WinterRacer
WinterRacer's picture
Apple tv sq problems
It's not music being transmitted over the (wireless) network, it's packets of data transmistted using well known network protocols.  If so many packets are lost such the original data cannot be reconstructed, you'll get a silence or click, not more treble or a less tight bass.
One obvious things to check is to make sure you haven't got any EQ set when using the mac. Failing that, the apple tv does resample everything to 48KHz.  This is generally considered to be inaudible, but you never know.
__________________
My System
ifor
ifor's picture
ifor
Points well made by WinterRacer.  I should have made it clear that my sound quality issue when wireless were dropouts rather than sound quality issues.
When I first started streaming from the iMac I had it set to adjust volume so that it was equal regardless of the recording volume.  Bad mistake!!  Presumably this would affect wired as well as wireless.
__________________
shafesk
shafesk's picture
RE: ifor
Thank you for your suggestion, I am not (thankfully) being affected by dropouts so I think I can avoid the hassle of having a wired connection. I don't know how to turn off Apple Tv resampling everything to
48khz, according to the dacmagic's display it is playing at 48khz now.....any idea how to do this? All I can see is the 16 bit option on the Apple Tv
__________________
Hi-fi:
Head-fi:
WinterRacer
RE: ifor
You can't turn it off, that's what the Apple TV does.  I'd be amazed if it's causing any problems though.  I use an Apple TV 3 and have no problems with sound quality with it.
Just to rule it out, have you tried a blind test to make sure the differences are real? It's easy to imagine differences, especially when we have the idea that absolutely everything affects sound quality pushed by various communities.
__________________
My System
shafesk
shafesk's picture
RE: ifor
I know what you mean about the placebo effect. However, it was a shock to me how the sound signature of my entire system changed through the ATV, hard to fathom why, I haven't experienced the same change via airport express and airplay. I think that it might be the optical cable I use to connect my ATV, as its different from the one I use for my mac. I don't believe in digital cables making a difference boohah, but I think I'll give it a try and see if it changes things.
__________________
Hi-fi:
Head-fi:
busb
busb's picture
RE: Airplay Sound Quality-does a wireless ...
I've just had to return to using my ATVII. I bought the newest model whose only difference is supposed to be 1080p HD video instead of 720p. I'm hoping that the new one is faulty 'cos I'm getting serious dropouts on audio over WiFi & will be returning it to the Apple shop I bought it from soon.
That aside, my ATV works very well - I usually use it via a PC connected to my router via Ethernet that then gets streamed to my ATV over WiFi. The ATV is connected to my M-DAC through a cheap 0.5m optical lead. Although I haven't done a recent comparison, the difference of streaming Apple lossless, 256k & 320k files versus my Rotel CDP (1m coax) was good enough for me not to worry. A good friend who's ears I trust felt the same - streaming over WiFi sounded no worse. He is 60 & I'm fast approaching the same so our ears are probably poorer than they used to be. I mention this because I recently tried the ABX MP3 comparison test here:
http://mp3ornot.com/
and failed badly! I'm not a huge fan of such short tests of music I'm not familar with anyhow but many see such tests as conclusive - I'm less convinced. iTunes sounds marginally better from my laptop through synchronous USB but close enough to be my imagination (as long as it runs on battery power!). I also use iTunes Match that streams at no higher than 256k when my PC is switched off in my bedroom - can't say I noticed any difference but neither am I particularly searching for one - I prefer to just enjoy music & fix any problems when I notice them.
__________________
"The optimist proclaims that we live in the best of all possible worlds - the pessimist fears this is true."
James Branch Cabell
_________________________________________________________
MAINApple TV2 & iTunes Match, CA Azur 751BD or Panasonic P42V20B into audiolab M-DAC, feeding a Primare A34.2 via XLRs, 2x 5m of Atlas Ascent 2 firing up Totem Arros.
ON THE HOOF: iPhone 4GS/Sennheiser MM450.
Another interest:
http://www.flickr.com/photos/busb/
shafesk
shafesk's picture
Thank you for your opinion busb, I would not have been worried if it was a tiny difference as I really like the convenience of the Apple Tv. However, the difference is striking and as streaming music is my main source I think its far too important not to get wrong. I'm trying out different cables atm to see what can bring it 90% of a wired connection to my mac. Wish me luck
__________________
Hi-fi:
Head-fi:
busb
busb's picture
I do indeed wish you luck Smile
As you don't know me you can conclude that either I've got cloth ears or that the ATV works fine for some people so it's just a matter of sorting out why it isn't for you. No surprises that I go with the latter!
__________________
James Branch Cabell
Another interest:
karl.hey
karl.hey's picture
Hi Shafin
Hope you got to the bottom of the ATV sound quality issues. I've been using my ATV2 for over a year now and I’m really happy with the sound quality. I can't tell the difference between the ATV wirelessly streamed music and a cable straight from my mac into the amp.
I mainly use Spotify premium streaming 320kbps into the ATV plugged directly into a Denon AVR-1906 (no separate DAC) with B&W 684 speakers.
the record spot
the record spot's picture
Currently using Spotify Premium over wireless into the ATV3.  I can't fault the sound quality, it's as good as the wired version and as good as the CD player.
__________________
Onkyo TX-8050 / Tannoy Revolution DC4 / Marantz SA7001-KI / Apple TV 3 / Sony PS3 320Gb / Denon DVD-3930
shafesk
shafesk's picture
karl.hey wrote:
Hi Shafin
Hey Karl, if you have the Denon then you can use a spdif cable to connect the ATV to your Denon, it will then use your Denon's dac and will considerably improve sound quality.
__________________
Hi-fi:
Head-fi:
shafesk
shafesk's picture
Thank you Karl and TRS for sharing your opinions. I have managed to sort out the problem, I was using a really cheapo spdif cable, I switched to a better built one and the lack of solidity disappeared. I don't think I can tell the difference between the ATV and a direct spdif connection to my mac anymore since last night. I'm not gonna open a can of worms and say digital cables make a difference but I rest my case.
Best Regards,
Shafin
__________________
Hi-fi:
Head-fi:
karl.hey
karl.hey's picture
Hi Shafin
What's the difference between a spdif and "normal" optical cable and why would using a spdfi bypass the ATV DAC and use the Denon one? Or am I missing the point entirely?
I'm pretty new to all this so please forgive my ignorance!
Thanks,
Karl
Paul.
Paul.'s picture
Spdif is the stubby square head optical connection, whereas the normal connector has the same shape as a 3.5mn jack.  You can get adapters between the two.
__________________
Paul's BR/805 system thread
(where the photos live) Paul's Flickr page
