Advice needed - Monitor Audio BR5 & NAD C320?
2 replies [Last post]
Smartnik
Smartnik's picture
 I have recently bought the Monitor Audio BR5 speakers and I am now looking for an amp to complement the system. My main music source will be the computer (just like in the topic below). Do you think that the NAD C320BEE amplifier will work well with my speakers? If not quite, can you recommend another amplifier in the same price range? Thanks a lot in advance for any advice you may give.
Nick
Andy Clough
Andy Clough's picture
Re: Advice needed - Monitor Audio BR5 & NAD C320?
Hi Nick
The NAD should work fine with the BR5s, but you might also want to consider the Cambridge Audio Azur 540A v2.0 (£250) or a Rotel RA-04 (£250). The Rotel is our Best Buy amp under £300 in the 2007 Awards.
__________________
Andy Clough is Brand Editor of What Hi-Fi? Sound and Vision and whathifi.com
Smartnik
Smartnik's picture
 Thank you Andy for your quick reply.
 I have just read your review of the RA-04 and I am really impressed. One question, though: do I understand that correctly that the only difference between Cambridge Audio 540A and 340A is the output power? If so, do I really need the 540A model, given that 340A's output power is the same as that of Rotel's (40W under 8 Ohms)?
