Advice needed: how to make my set-up "warmer" (on a budget)
7 replies [Last post]
rgrainger
rgrainger's picture
Hi
I currently have a pretty old setup - mid 90s amp (Cambridge Audio AI-1110) and speakers (Gale Reference Monitors). It sounds OK, but I'd like to "warm up" the sound. The amp is on its last legs (most of the inputs no longer work), and I'll be replacing it in the mid future, probably with a Marantz.
Aside from the amp, however, which I'm definately going to replace anyway in due course, what should I purchase to "warm up" the sound, what should it be? New speakers or subwoofer? My budget is up to £250.
I listen to quite a wide variety of music, but primarily it's rock/acoustic and electronic (but not dance). I'm not interested in a home cinema setup, or great amplitude; just a warmer sound.
Thanks in advance for any suggestions.
Robert
kev g
kev g's picture
RE: Advice needed: how to make my set-up "warmer" (on a budget)
With a Marantz amp I would audition some Tannoy speakers, no sub
__________________
Hi-Fi - Arcam A75+ amp, Marantz CD6000OSE KI Sig, Sony ST-SE700 Tuner*, Tannoy R2 speakers
Cables - Van Den Hul The First Ultimate*, Van Den Hul The Bay, Chord Odyssey 2*, Audusa Eupen mains cable, Tacima CS929 mains block.
A/V Sony 32EX503, Sony BDV-E370*, Humax Foxsat HDR*
* Second Hand
Fulci
Fulci's picture
What is the source?
You could start by trying new cables and see if it improves. You can make a pair of Klotz AC110 with Neutrik plugs under £10. A new speaker cable could help too, the Rega Quattro are very good and not very expensive. You could try a power chord too, that made a hell of a difference in simbilance, fatigue and shrillness to my old Audiolab 8000A. It was not night and day difference, but you could listen to it for a lot longer without getting tired.
If your source is digital, like a CD player, you could try a new DAC and keep it for when you get your new amplifier. A Beresford Bushmaster DAC is a brilliant machine that can be yours for under £200. Avoid the DacMagic as it's very harsh and a far inferior machine.
Finally, if you are handy with a soldering iron, you could try replacing the capacitors in the amplifier for Elna Silmic II and Kendeil which should give you a much sweeter and warm sound, and a lot more dynamics, given the age of it. My old Audiolab became a hell of a great amplifier after this mod.
__________________
Apple Airport Express > Beresford Bushmaster DAC > Rega Brio-R > Rega RS3
Fulci
Fulci's picture
Sorry, just saw you were actually looking for new amp and speakers.
If you can get Rega RS1 speakers for £250, you must put them on your list.
Also, you could try some NAD amps, it's hard to get warmer sound than that for your budget.
__________________
BigH
BigH's picture
Online
Rega RS1s are about £440 new unless you meant used ones?
You could look out for Arcam amps like the Alpha 9 for around £200 used, that is fairly warm.
__________________
Marantz 63SE AVI ADM9RSS
MeanandGreen
MeanandGreen's picture
NAD would be my prefered choice for amplification, but Marantz ,may well give you the sound you want. I'd suggest Living with the new amp for little while before deciding what to buy next. The amp change on it's own may be enough, or if it isn't at least you will have an idea of what tonal qualities you will need to look for with new speakers having lived with it for a while.
__________________
NAD C326BEE Amplifier, Sony CDP-XB930 CD Player, Pioneer PDR-509 CD Recorder, Arcam irDock with iPod Touch, B&W DM 601 S3 speakers, Jamo 20"Stands, Revolver Rack, QED cabling throughout, Sennheiser HD 518 & HD 565 Ovation Headphones, Beyerdynamic DTX-101iE ear buds.
rgrainger
rgrainger's picture
Thanks everyone for the replies.
I think I'll take MeanandGreen's advice, and buy the amp first. My amp is knackered, and needs to be replaced anyway, whreas my speakers work fine (and, from the limited information online, are regarded as very good for budget speakers; I have the original model with the rectangular tweeter, which is supposedly the best version). If the amp doesn't warm up the sound then I'll look more into speakers.
I take it then that if the amp doesn't warm things up on its own, I should spend the £250 on replacing the speakers, rather than keeping them and adding a sub-woofer to the set-up?
lindsayt
lindsayt's picture
rgrainger, have you tried using a bit of contact cleaner on your amplifier selector switches?
Google "amplifier contact cleaner selector switch" and click on the youtube links for a little instructional video showing you how amazingly easy it is to do if you have non sealed switches.
Just seems a shame to dump what may well be a perfectly good amp for the sake of £5 worth of contact cleaner  plus a few minutes of your time.
If you can return it to fully working condition you may still wish to get another amp. But then at least you've got a benchmark with which to compare any new amp. There's no guarantee that the new amp will sound better in your system.
