90s Arcam, Marantz, Mission setup, time to upgrade??
48 replies [Last post]
Chrisjohnwright
Chrisjohnwright's picture
Hi
I've got a loved but ancient combination of Marantz CD52SE, Arcam Alpha amp and Mission 752 floor standers. Setup works fine but am thinking about getting into the new millennium with Marantz 6004 amp and 6004 CD player. 1, Do you think I'll see an improvement? And 2. Will this new combination still work with the same speakers?
altruistic.lemon
altruistic.lemon's picture
Online
RE: 90s Arcam, Marantz, Mission setup, time to upgrade??
Sure, but I'd look at the speakers, as your CD player and amp are at least as good as the replacements you suggest. Which alpha amp by the way?
MajorFubar
MajorFubar's picture
^^^WHS. IMO, you'd need to buy further-up the current range of Marantz products to make it worth your while, because your current amp and CD player are no embarrassments.  Blow your complete budget on a fresh set of speakers that are several rungs up from your current models.
__________________
Main gear: Mac Mini > HRT Streamer II+ > Cyrus 2 + PSX  > Cyrus tuner > Mission 794
Also cluttering-up the place:
Thorens TD160 no cartridge; Technics SL-P777; Marantz CD63 mkII KI; Marantz PM66 KI; Nakamichi DR-1
ID.
ID.'s picture
I had an Alpha 9 and I'd still take it over any of the Marantz 5004 through 8004. Don't assume that the technology has made huge advances just because, AV amps for example, get new models released every year. CD players, speakers and amps are pretty mature technologies, so I think most changes are pretty incremental. I think you probably get more bang for your buck at the budget end, but that doesn't necessarily mean that current budget kit is superior to kit that cost twice that amount when it was released in the 90's.
__________________
Observe the signature in its natural habitat.
the record spot
the record spot's picture
Hang on to the 752 if you do nothing else. By far and away the best of the the three items. The amp would be my candidate as it has long since been surpassed and bettered. To better the Missions you'll be handing over a lot of cash and I mean well north of £500 new.  Wonderful sound, clarity, depth... one of the few products that had it all.
The CD player is still a good one, has a coax output and stacks up well, but it too can be equalled but for a lot less money than you'd need to spend on the speakers. You might also consider if you want to keep the box count down so a new CD player with digital inputs for computer, TV, etc, would be worth considering.
The Missions, however, are clearly the keepers;  one of this country's best HiFi products of the last 30 years  - IMHO.
__________________
Onkyo TX-NR818 / Tannoy Revolution DC4 / Marantz SA7001-KI
eggontoast
eggontoast's picture
The record spot, how can you make such a judgement on his alpha amp when we don't even know which one it is ?
the record spot
From my perspective, pretty easily. The Arcam amps were good, decent, but nothing so special I'd get rid of the 752 for. Up until the 9 and 10 came out, they were IMO, nothing to get to worked up over. I had an Alpha 5 for years and I stand by what I say. Personally, is be inclined to keep it all as it's probably very good - Mission and Arcam worked well together. I had the same CDP and used the 751 speaker at the time, but the amp can be and is bettered by others.
__________________
altruistic.lemon
Online
Perhaps best to ask the OP which amp he has first, plus also what his budget is.
Some of the alpha ange were very good indeed. I wouldn't be throwing them out in a hurry. The speakers, though good, can be improved upon.
the record spot
If it's early 90s then it's the Alpha 5, 5+ and 6. The 7, 8, etc not appearing till later, then there are any number of 40-70w amps that's do the job.  Heaps. If the budget is less than £500 the 752s play a strong card and can hold their own up further up the scale.
Where do you see the improvement in the speakers AL? Have you heard the 752? And have you heard that combination the OP has?
__________________
altruistic.lemon
Online
Still makes sense to wait until the OP responds with an idea of budget and what model of the Alphas he has. Anything 7+ won't be easy to beat.
Yes, heard the 752s with an Arcam Alpha 7 or 8 if memory is correct. Fine, but I wasn't particularly taken with the speakers - never really liked the Mission sound, although I had the Mission 780se at home at that stage. This was in Oz, by the way, so it is a while ago.
Chrisjohnwright
Thanks. It's an Arcam II
Chrisjohnwright
Let me try that again.
The amp is an Alpha 2, was a hand me down, not even sure what year that was made but I know pretty old.
Was thinking about c.£500 all in which would have overed the Marantz duo.
Have always liked the 752s, never really had a problem with their sound. The start point here was, would £500 get me a dramatically better sounding setup? My AV system is pretty nonexistent so if the answer is no then may spend on that instead.
Thanks all for your views.
BigH
BigH's picture
Online
The Alpha 2 was about 91, I have the Alpha 3 which is very good, I would consider getting a Aplha 9 which are about £200.
__________________
Marantz 63SE AVI ADM9RSS
Chrisjohnwright
Thanks BigH.
So is the view I should stick or replace?
the record spot
Depends really; do you want to add digital sources?  You've already mentioned expanding your AV setup, so you could get one of Onkyo's excellent amps.  Not sure if you can but you might be able to connect your Arcam to it.  That said, Onkyo's AV amps work a treat with music as they do movies, so might be worth a compare.  They also come with network connectivity and Spotify onboard too.
__________________
BigH
BigH's picture
Online
Chrisjohnwright wrote:
Thanks BigH.
I would keep the cd player or maybe buy a Marantz 63SE 2 KI which are only about £80 on an auction site. Maybe buy the an Aplha 9 amp, keep the speakers for now. Having heard a load of new gear at prices around £1,000 each item I would buy used rather than new, really I did not find a huge improvement, in fact in some ways it was worse than my old system.
__________________
