£600 budget amp and cd
Thu, Aug 9 2007, 9:31PM
Loking for some advice for amp and cd or dvd with good cd playback.
in my country i can only found Marantz, Denon, Rotel ,Onkyo and Harman Kardon.
Fri, Aug 10 2007, 5:43PM
#2
Thanks Razz i was loking for some extra buget and this combination DENON-PMA1500AE with MARANTZ SA7001 i meen that will be very good combination for the money but if i cant found some extra money i think DENON DCD-700AE will be good replace and also this DENON have pitch control.
Sat, Aug 11 2007, 10:13AM
#3
Denon DCD700AE CD player + Pioneer A-A6-J Amp = smooth presentation but with plenty of attack and liquid treble.
- Login to post comments
I
would recommend equipment from Marantz, Rotel and Denon - at this price they
all have very good and competitive units. My PERSONAL favourite is Marantz's
amplifier PM7001 (350 pounds). This partnered with any Marantz CD player for
the remaining amount of up to 600 pounds would make an exceptional system for the
money of a truly audiophile quality. However also worth auditioning are systems
from Rotel - the RCD-06 CD player and the highly acclaimed amp RA-04, at around
your proposed budget. Also for this budget you could consider Denon's PMA-700AE
amp and DCD-700AE CD player both with favourable reviews in the
specialist press.
Good luck,
Razz
