14 posts / 0 new
Last post
Thompsonuxb's picture
Last seen: 9 months 3 days ago
369' turn.....doh!
I don't know about you guys, but when I generate a thread that gets over 100 replys I always feel slightly under pressure with the follow up. This is what it must be like to be a pop star...... Blum 3
Anyway not that I want to bore you, but pls allow me to share -Yes I have made the full 360degree turn and gone back, thats right back to the amp I started out with over a year ago before I went on a quest to 'improve'/'upgrade' my stereophonic reproduction. All I've found out is if you have a genuinly good sounding set up., stick with it chances are you'll never be happy with changes and spend your time trying to get new kit to sound like your original kit.
My old amp the Yamaha DSP-AX620 is back!
And I don't know but this generation of amp/reciever (circa 2005) were genuinly outstanding for stereo playback, Ive read other post with the same generation suggesting the same thing about how good these Yamaha are - its shown up a pair of modern £700 amps and basically is a much better all rounder than the rx-a1020, which is superior as a surround amp but in stereo is a little soft through my speakers.
I just had to share
BenLaw's picture
Last seen: 1 year 11 months ago
RE: 369' turn.....doh!
If you'd just turned 9 degrees you'd have achieved the same result and be a lot less tired.
I am the danger.
davedotco's picture
Online
Last seen: 23 hours 58 min ago
Thompsonuxb wrote:
I don't know about you guys, but when I generate a thread that gets over 100 replys I always feel slightly under pressure with the follow up. This is what it must be like to be a pop star...... Blum 3 Anyway not that I want to bore you, but pls allow me to share -Yes I have made the full 360degree turn and gone back, thats right back to the amp I started out with over a year ago before I went on a quest to 'improve'/'upgrade' my stereophonic reproduction. All I've found out is if you have a genuinly good sounding set up., stick with it chances are you'll never be happy with changes and spend your time trying to get new kit to sound like your original kit. My old amp the Yamaha DSP-AX620 is back! And I don't know but this generation of amp/reciever (circa 2005) were genuinly outstanding for stereo playback, Ive read other post with the same generation suggesting the same thing about how good these Yamaha are - its shown up a pair of modern £700 amps and basically is a much better all rounder than the rx-a1020, which is superior as a surround amp but in stereo is a little soft through my speakers. I just had to share
During your quest to upgrade the system by changing the amplifier, did you buy (or otherwise spend time with) any of the other units?
chebby's picture
Online
Last seen: 10 hours 15 min ago
369' = 369 feet.
Should have used the symbol for degrees...
369°
iPad Mini 3 • iPhone 6 • B&W P3 • Mac Mini • Apple TV3 • Quad Vena • Pro-ject Tuner Box S • Audio-Note AX-Two
davedotco's picture
Online
chebby wrote:
369' = 369 feet.
369°
Actually since the OP has defined his motion as rotational, then the 369' referes to 369 minutes (of arc)
Or a little over 6º.
The logic at the time was the set up sounded great - but I wanted more, more ambience, more 3dness, more realism...just more, more texture, more seperation, more!
The speakers, CD player, interconnect, speaker cable had delivered so considering I was using a what was a DSP (reciever) I thought thats were I would gain  ...... but I have to take it that this system has 'synergy', accidental and on paper the sound they'll produce would be nothing special but in the real world, to my ears. it really works.
davedotco's picture
Online
Thompsonuxb wrote:
Fair comment, any chance of answering the question.
No...no, you guys misunderstand the humour.
369' (were is the degree symbol on the keyboard) means I over rotated or stumbled a little, you know like when you do a spin, like Micheal Jackson use to do, back in the day..... what?... you don't get it?...  thats the extra 9 degrees
chebby's picture
Online
davedotco wrote:
chebby wrote:
369' = 369 feet.
369°
It's also possible he could have turned both 369 feet and 369° (if he was walking around a circle with a circumference of 360 feet).
no, it was the amp i wanted to upgrade ......why?
BenLaw's picture
chebby wrote:
davedotco wrote:
chebby wrote:
369' = 369 feet.
369°
:grin: It's also possible it took him 369 minutes (if he was going at approximately 0.0114 mph).
I am the danger.
matthewpiano's picture
Last seen: 1 day 18 hours ago
Ultiamtely, if a particular set-up works best for you, then its the right one and prices, names, and reputation don't make a jot of difference.  If you enjoy the Yamaha so much more than your newer amps, then stick with it and enjoy the music.
Rega RP3/Elys2/TT PSU- Denon DCD720ae - Denon PMA720ae - Dynaudio DM2/6 - Atlas Equator 2.0 - Beyer DT-770PRO - Mission stands
davedotco's picture
Online
Sorry I was not clear.
What I was trying (and failing) to ask was whether you were able to try any of the other amplifiers (units) in your system, live with then a while maybe, and if so, what your rections were.
Yes 3 amps.
Audiolab 8200a a month, Rotel ra-1520 a year and more recently the Yamaha RX-A1020 (now resigned to 5.1 duties).
The 8200a was not a nice amp in my system - good looking , solid build but the sound was not to my taste shall we say. sound did change but found it siblant & harsh with a detached bass (I'm sure I had a faulty one - but it put me off the brand)
The 1520 was better, but lacked something music lacked body/timbre it was a fatiguing amp in my system narrow and shallow sound stage, voices lacked realism but it was clean sounding.
The 1020 is complicated and requires alot of tweeking which needs a tv - generally good midrange, wide soundstage - soft bass and rounded top end - but funnily enough it sounds great in 5.1 - really weird it controls a sub really well (will try it again one day)
I do agree with something you said the other day - these modern amps are designed to deliver their peek levels at around the 9 o'clock mark. This I found with these amps - it was useful if playing a CD with a very low EQ level - but the scope was very narrow for listening.really poor attenuation.
Log in to post comments
