£300 or 2k..?
24 replies [Last post]
letsavit
letsavit's picture
Hi
My old system has been in the garage since i moved in my current home about a year ago, it is a pioneer a400,marantz cd67 and some tannoy M3's, as you can see by my the kit i havnt been into hi fi for a few years. Now doing my living room up and fancy a new system to go in it, the rooms about 14x12 and there is not really the room for a stereo on a stand and floorstanding speakers, even if i try to create some space the missis would moan and my 3&4 year old's would love playing with it...! So its got to be on a shelf between the chimney stack.
Fancy looking at the Naim 5i CD and AMP but am i wasting my money having this and some £500 bookshelf speakers sitting on a shelf? or should i just bite the bullet and get the onyke mini system with some F1's and forget hi fi for another 10 years.
Gwyndy
Gwyndy's picture
Re: "300 or 2k..?
How long is the shelf?
You could consider going for a more expensive system than the Onkyo mini-system and allocate some of your budget to isolation platforms, Nordost Pulsar Points et cetera. They may help make the most of whatever you do buy through isolating the components from some of the vibration effects.
nads
nads's picture
Re: "300 or 2k..?
user="letsavit" wrote:
Hi
yes, it does not seem that you have missed it.
Or you could be sneaky and go down the AV route but get a AV Amp that is respectable for Music....
__________________
Not a HiFi Nut. Just has a pile of Nads.
raypalmer
raypalmer's picture
Re: "300 or 2k..?
Never bite the bullet!
There's real estate in between Naim and Mini Systems mate. If I were you I'd still spend the 2k, just reallign so that 1k of it goes into crispy new speakers, it's so common to blow amp and source all out of proportion imho. If your speakers aren't up to it there's no point. Try looking at Dali, ProAc and my beloved Totem (et al). Seriously go audition proper speakers, there's loads of reasonably priced kit out there to run them that will sound beautiful.
drummerman
drummerman's picture
Re: "300 or 2k..?
I dont think you'd be waisting money. Get the best you can afford and like after listening to it. Dont worry about racks/stands etc. Of course you can optimise performance but a quality system will shine through. You can always add these things later.
__________________
Pretty ... and pretty proud of it
Hughes123
Hughes123's picture
Re: "300 or 2k..?
Two ideas to bear in mind: "The law of diminishing value" and "A job worth doing, is a job worth doing properly". Your decision! : )
Note: Go with the second phrase....
drummerman
Re: "300 or 2k..?
I would normally agree but most people dont have what you and I would call an ideal set up, be that because of children, room layout etc. ...
... by the way, have you sorted your bedroom out with them Evo's squeezed in next to your (lovely) system ... ?
Wink
__________________
Hughes123
Hughes123's picture
Re: "300 or 2k..?
Wink
Well....no, not yet....I can't really move it...I don't have another place for it to go.....They are 1.2m apart!
Hughes123
Hughes123's picture
Re: "300 or 2k..?
...but my new garage set-up is awsome! Got all my old equipment in there (look at my signature) and it really does have room to breathe! Oh, and those Akai old micro system speakers (vener finished ones from 1997) are really good! DVD player was the best one money could buy at the time, 2001(or you could get in a shop)also!
raypalmer
raypalmer's picture
Re: "300 or 2k..?
Oh man we're going off-topic...
Hughes link me the pics of your set up man. I want to see all those creamy FMJ's.
See my new setup in the "what's in a naim?" post??? I'm quite chuffed.
Thaiman
Thaiman's picture
Re: "300 or 2k..?
2K! Wink
__________________
TW Raven AC - Soundsmith SG-410 - MSB 202 - Gershman Acoustics Black Swan - Audioquest K9
Hughes123
Hughes123's picture
Re: "300 or 2k..?
letsavit
letsavit's picture
Re: "300 or 2k..?
Thanks for the replies..Wink
I know there is good stuff inbetween £300 and 2k but what i really trying to say is any worth buying any if not set up correctly?
Have been looking at everything from a mini system to the Nad set up at Superfi to Roskan and Naim. Think Naim is there because its the stuff i wanted years ago but couldnt afford, i can now..
what i'm really trying to say is at what price does hifi become a total waste if not set up correctly. Say i go for middle ground, the NAD stuff for 1k. I know its going to sound much better on a shelf than a mini but is it worth spending more after this without much approvment because its not set up correctly.
The other issue i going to have is a demo, what sounds nice in the shop will not represent what i have at home ie, a chimney, two shelfs either side in each alcove.
Am i better with two solid shelfs and front ported speakers on each side of the chimney or how about brackets?
raypalmer
raypalmer's picture
Re: "300 or 2k..?
Ooh well I'd say you should DEF buy Naim if it's what you've always wanted. Otherwise you'll just toss whatever you get for Naim sooner or later. You should be able to get an in-home demo if you're dropping this kind of money so testing it out in ye olde awkward room shouldn't be too hard. Don't be afraid to go through a few speakers as testers, if you go to a good hifi shop they won't mind, too much.
As far as the speaker question, if floorstanders are a definite no-go then it sounds like front-ported would be the way to go. Provided the bookshelf one uses is solid-as-heck, anchored by a couple hundred books and you stick some brass cones, or a mat or blu-tac under the speakers you should recieve good sounds. As far as what there is in front-ported speakers... I can't think of any of the top of my head, but the forum will know. If you decide to go that route just start a new thread demanding good front holes.
JoelSim
JoelSim's picture
Re: "300 or 2k..?
Why spend £300 if you have £2k to spend. I guarantee that if you spend £2k you will spend much more time listening to it, and it will become much more part of your life again.
__________________
Unison Research CDE, Leema Tucana 2, Kudos C2 and some cables.
huddo
huddo's picture
Re: "300 or 2k..?
Yep, what Joel said.
__________________
