23 posts / 0 new
Last post
Michaelholder1's picture
Last seen: 11 months 3 weeks ago
2nd Hand Integrated amplifier to match B&W Dm602.5 S3s
I am currently upgrading my system and need am looking for a 2nd hand integrated amp for around £100-150 to match my B&W dm602.5 s3s. I will probably get a cd player to match the amp, I use my laptop a lot for music so perhaps an integrated DAC would be useful or some options for a seperate DAC instead. I know the Marantz pm6005 has an integrated dac without a usb input but I could maybe get a usb to optical or coaxial convertor if anyone has any opinions on them as well.
My music taste is very eclectic so versatility is important however I do like a good bassy sound.
RE: 2nd Hand Integrated amplifier to match B&W Dm602.5 S3s
Vladimir's picture
Last seen: 9 months 3 days ago
I would go for the Rotel RA-1062 or RA-980BX 2nd hand.
Are they not very old amplifiers? I always feel that although the amps are pretty good, surely a newer amplifiers must be better as there must be some sort of incremental increase in quality over such a long time?
Or were they very expensive at the time?
Vladimir's picture
The 1062 is not very old. You can find one that is 5-6 years old and it would work quite well for many years to come. If the older 980BX is from a first owner that would be a good buy as well.
When you say "old" it means 10-20 years and "very old" 30+. It is quite normal to buy 2nd hand up to 10 years old without any need of servicing.
For £100-150 you wont get an excellent amp that is new.
stavvy's picture
Last seen: 3 months 2 days ago
I have the pioneer a50 powering B&W 685 which to my ears sounds immense.  Some of pioneer's entry level amps (A10 A20 and A30) may fit your budget
Pioneer PD30S SACD player, N30S Network Streamer, A50S Amp
Bowers Wilkins 685
Vladimir's picture
The B&W DM602.5 S3s need high current amps since they drop down as low as 3 ohms and they are 88db.
d_a_n1979's picture
Last seen: 9 months 2 weeks ago
NAD C320BEE all the way
Tank of an amp; bags of power and will drive the 602.5 S3's well
(I should know as I had that combo for a while before moving to the 685's etc...)
Still got the NAD C320BEE; bought it early 2000's new and will never part with it. It's a stuinning amp and still blows me away today!
It's ran everything from KEF LS50's to Neat Motive 2's and even ran it with my friends B&W 805's (all be it briefly)!
It'll drive all sorts of speakers and you can generally get one via eBay for less than £100! Smile
Hope to help
2012 Mac Mini/iTunes & iTunes Match - ATV3 (AirPlay) - Cyrus 8DAC - KEF LS50's - Tellurium Q Blue cables - Chord Cobra VEE 3 interconnects
TrevC's picture
Last seen: 1 week 5 days ago
Richer sounds have a Pioneer going for £149, 50 watts per channel. I would go for that rather than risk the unknown quantity that is a second hand one.
Thanks for the replies, yeah sorry I only knew the older rotel amp and presumed the Ra-1062 was the same age. It seems to be reviewed very well and looks very good for me. I understand that people do buy amps up to 30 years old still but it just seems to me that due to the incredible advances electrical technology has made of the past 20 years that surely an amp made in the past decade must surely have technology in it which results in a better product than a similarly priced amp from 20 years ago?
I actually had the Nad 320BEE but i found it a little dull sounding in my opinion, I did like it mind, would have kept it but my friend touched the speaker wires together an blew it unfortunately so thought id try something different.
So are people saying that the pioneers arent powerful enough to drive the speakers?
I mean not high current enough rather than not powerful enough. I take it high current amps are able to cope with lower impedances?
TrevC's picture
If an amplifier is capable of producing close to double the power output at 4 ohms than it is at at 8 ohms then it is a high current design, but unfortunately these things are never tested.
Vladimir's picture
Rotel RA-1062 High Current Stereo Integrated Amplifier
Rotel RA-980BX has damping factor of 1000, 100W RMS p/c and peak current of 80A. But it really depends in what condition it is. Its AB class but high biased AB, so its quite hot in normal operation. If you play low impedances too loud for long it heats up and goes in protection. Although its powerfull, it is not a party amp.
Are you saying increasing the volume on the amp reduces the impedance? Im not sure if thats how the volume dial works is it?
Vladimir's picture
*If you play the amp too loud with speakers with low impedance.....
I apologize, english isn't my native language.  Smile
Oh sorry i just completely misread that, that makes sense dont worry.
Pages
Log in to post comments
