Which IEMs do I buy?
Mon, Nov 19 2012, 4:14PM
Hi All.
Thanks in advance for any replies:)
My SA6s recently bit the dust and I need to replace them.
I like basey sound but need a mic and will be using Comply tips because I found them comfortable.
My budget is about £150 but i am now totally stuck having had so much differing advice. I can push to £200 if needs be...
What do I do??
Patrick
- Login to post comments
http://www.hifiheadphones.co.uk/in-ear-isolating-headphones-ct-29.html?sort=3d
My favorite reference above: The Shure 425 and 315 are good, so is the Sennheiser IE60.
SoundMagic HP200, Final Audio FI-BA-SS, V-Moda M100, Sennheiser IE800, Beyer DT770LE, FiiO E07K/MicroStreamer/Vamp Verza DAC/amps, FiiO E12/Zen Head amps.
