4 posts / 0 new
Last post
fj177's picture
Last seen: 3 years 9 months ago
Noise Cancelling Headphones Question
Hi, i just bought the sennheiser PXC 310 noise cancelling headphones based on the What Hifi reviews.  First pair I have had but noise cancelling seems pretty good, just had a quick question - when listening to my i pod and activating noise cancelling, the i pod seems to go much quieter and a hiss is produced as well.  I then have to turn the i pod volume up to hear at the same levels as without noise cancelling.  Is this normal?  I just thought the idea with noise cancelling was you would be able to listen without turning up the volume to protect your ears
thanks
Phlegm's picture
RE: Noise Cancelling Headphones Question
Sounds normal to me and just the electronic algorithms kicking in. Smile
bigboss's picture
Last seen: 5 days 2 hours ago
Never heard the Sennheiser, but doesn't happen with my Bose QC15 & Goldring NS1000.
fj177's picture
Ok thanks for the info - just having to turn the i pod up to max to hear it  on the train etc when noise cancelling is on, just wasn't sure if that was right
thanks
Log in to post comments
