need new lead
2 replies [Last post]
smuggs
smuggs's picture
ive got goldring ns1000 my little lad has done something so it only comes out of the left ear and the odd time if you keep twisting it around you may get both. im sure there is almost a clean break inside the cable it is a 1m qed lead can you get them on there own
__________________
Samsung 46 led tv-denon1909-skyhd-wd tv live -wd my book 2tb nas-apple tv3-xbox360-accer 7540 laptop-dac magic-genie2(2mred)-Montior Audio Br5's Br-LCR Br1's Brw10 sub-ipad(2g)-samsung gs2-akg 450's
idc
idc's picture
Re: need new lead
I found the cable to a bit too short and hunted high and low to find a longer cable which fitted the socket on the headphones. but no joy and I ended up using an extension cable instead. I would get in touch with Goldring and/or QED who make the cables for Goldring. They must have spares.
__________________
Internet - laptop - DAC - amp - lots of headphones.
http://idc1966.blogspot.co.uk/
"A music lover will stop what he's doing and stay glued to a favorite piece of music even if it's coming over a 3" speaker or a public-address system..." - Ken Rockwell
smuggs
smuggs's picture
Re: need new lead
ive just had a look and no joy so what im after is a tiny 3.5mm to a 3.5mm female socket that can plug in and be left there that will sit almost flush with the housing and then i can use any lead.
__________________
