Monster Beat Dr. Dre Studio Headphones - Dissapointment
I just came back from Dubai, UAE last weekend where on the last day I was there, I purchased this headphones from Virgin Megastore in Mall of the Emirates. I was rushing to the airport hence did not test them out after purchasing.I only tested the the display unit in the shop and the sound really blew me away. It is better than the Bose.
However, when I first statrted using on the flight back to Kuala Lumpur, it did not function as its supposed to be. The mute button on the right cup had to be constantly touched in order to get the sound. I mean literally touch, not pressed. Its like there some static thingy going on there. Take my finger away, then the sound is gone.
It was a good thing that I still had my Sennheiser earphones for the rest of the flight.
Once in KL, I emailed Monsters Cable US but since it was the weekend, had to wait till Monday. But no respond till Tuesday so I re-emailed them on Tuesday. They then replied for me to contact their sole distibutor in KL but I have never seen these phones sold here.They also gave the contacts of their distributor in UAE. Was told to contact either one of them to getr a replacement unit. If these 2 distributors do not want to replace, then I have to send the unit back to US for a replacement.
A bit dissapointed that I have to go through all these trouble when there is a lot of hype of the quality of these phones by Monsters.
Anyone else ever experienced the same problem with this unit?
idc,
Thanks. Yes more bad news. The sole distributor in in Malaysia does not want to replace my unit with a new. Mosnter Cable USA will but I will have to courier them the unit. That will be easily another 3 to 4 weeks.
El Hefe, sorry to hear about what happened to your Monster Beat headphones. If you could get those issues worked out I'm sure you'll have a blast with them. Another "common" issue that I've heard on US forums is that the plastic band will crack around the metal screws. Seen it happened personally at a local Apple store. But I'm sure if you take good care of them that won't be a problem.
I have finally sent the damaged unit to Monsters in Netehrlands after a few confusion on their side. The confusion came when their US counterpart replied to my email and after a week of communicating, Monsters Europe issued me the RMA number (number used to accept goods to their warehouse). Hence, didnt know whether to send it to USA or Netherlands. Finally they confirmed with me to send the unit to Netherlands. They will replace the unit with a new one but it will take 4 to 6 weeks.
If it is any consolation El Hefe, this is the first Dr Dre thread I have seen that complained of a fault. You have probably just been unlucky and since you lack easy access to a shop to return them to, that is obviously going to make it more complicated.
Internet - laptop - DAC - amp - lots of headphones.
http://idc1966.blogspot.co.uk/
"A music lover will stop what he's doing and stay glued to a favorite piece of music even if it's coming over a 3" speaker or a public-address system..." - Ken Rockwell
