MF X-CAN V2 - Zero volume?
7 replies [Last post]
El Hefe
El Hefe's picture
Hi all,
Recently purchased this unit from ebay and have been running it for nearly 5 days now. Really like the warm sound of it.
However, I have a question. Is it normal to hear a very low volume of music coming out of the headphones eventhough the unit volume knob is at zero? FYI, I hooked it up via the tape out of my X-A1.
__________________
HiFi: ClearAudio Concept TT, Musical Fidelity M6i and M6 DAC, M1s (CDT, CLiC, ViNL), Onkyo TA2600, SONY MDSJA20ES MDP, ProAc D18 with full Siltech cabling.
HT: Samsung UA55B7000 LED, OPPO BDP 95-EU,Marantz DV4003, Yamaha RX-V2067, Philips DVDR7300H, Infinity Primus Center, Wharfedale WH2, SW15 Sub, Mission M34i with full QED cabling
Bedroom: BRIK Audio BT Stage, Bose WAVE Music Sytem III
HeadFi: Alessandro Grado MS Pro, Bryston BHA-1 headphone Amp.
Office: iTunes, UD100 USB DAC, Bose Companion II, Musical Fidelity HPA headphone amp, Bose Over The Ear
matengawhat
matengawhat's picture
Re: MF X-CAN V2 - Zero volume?
i don't think anything to worry about - i've had amps before where when volume at minumum if you put haed near speakers you can still hear music
__________________
El Hefe
El Hefe's picture
matengawhat,
Thanks a lot for the assuarance. Put my mind to peace.
__________________
jcoops16
jcoops16's picture
What headphones are using with it? I have a hybrid amp like your x-can and with my grado's at zero volume I hear nothing but with my lower impedance Denon's I can still hear music out of them at zero volume.
El Hefe
El Hefe's picture
Ahhh it depends on the headphones as well is it?
 Well the sound could be heard when I use my Senns and Shure earphones and also BOSE over the ears headphones.
__________________
idc
idc's picture
I am sure it is because you have it set up with the tape loop. I had mine connected with one set of phonos into aux. I have also notuiced that I get more background hiis with my Grados as opposed to AKG and Goldring, the Grados at 32ohms having the lowest impedence.
__________________
Internet - laptop - DAC - amp - lots of headphones.
http://idc1966.blogspot.co.uk/
"A music lover will stop what he's doing and stay glued to a favorite piece of music even if it's coming over a 3" speaker or a public-address system..." - Ken Rockwell
El Hefe
El Hefe's picture
Not sure of the BOSE's impedance but yes, maybe because of the tape loop. Oh well, as long as its not the XCAN.
__________________
idc
idc's picture
I cant find ratings for Bose headphones for ohms or db/mW to find out the sensitivity. The lower the ohms and the higher the db/mW (or db/V) the more sensitive headphones are.
__________________
