Improving comfort of SR80
Hi all,
I have had my SR80 over a year now, occasional use, but becoming more frequent. Love the sound, shame I can't use them at work, where most of my listening done, due to the openess of them. Anyway, was just wondering if anyone had any tips on making them a bit more comfortable? I certainly don't find them as comfy as my older Beyers, and find them crushing my ears a bit, should I bend the headband to loosen the grip? any thoughts?
Get grado's new foam pads which are now used in the new SR60 & 80i models. Much more comfortable than the previous pads I think. They cost around 20-£25 a pair.stanleyk:Hi all,
You can bend the headband, just don't overdo it! (bending gently and incrementaly from the middle I should have added)
Sizzers:You can bend the headband, just don't overdo it!
The headband is designed to fit your head, be it a melon or not. They appreciate the sound of their cans is good enough for the product to "fit" its user. If it persists buy some more pads from Grado for about a tenner.
Changing the pads would change the sound, most people bend the headband alittle and wash the pads in warm soapy water to soften them up. I dont think their ever gonner be as comfortable as your beyers.
I admit, I have a particularly large head. I have however purchased and used a great many variety of Grado headphones and I can confirm you will get used to it. Otherwise the sound quality is just worth the pain.
- Login to post comments
Mine are 9 years old and I am sure with prolonged use they have widened a bit. Two suggestions.
Get a headstand like this http://www.stoneaudio.co.uk/ and use it to put a streach on the headband. Or be creative. I have seen breeze blocks covered in fabric to bottles being used to keep the cans apart.
Get the full sized pads like this http://www.hificables.co.uk/11412/Grado-Spare-Ear-Pads-.html which I use and find more comfortable.
Internet - laptop - DAC - amp - lots of headphones.
http://idc1966.blogspot.co.uk/
"A music lover will stop what he's doing and stay glued to a favorite piece of music even if it's coming over a 3" speaker or a public-address system..." - Ken Rockwell
