2 posts / 0 new
Last post
Josephmatthewellis's picture
Last seen: 2 years 5 months ago
Help! Advice needed
Hi, I don't really know too much about hifi- just trying to get a low budget set up. I bought some q acoustics 1010i cheap on ebay, just looking at hooking them up to a denon dm39dab (which I haven't purchased yet). Would a turntable work through the anolog input? Do I need a preamp for this? Or is it definitely worth blowing my budget and investing in the denon pma 720 and matching CD player? Thanks in advance!
ID.
ID.'s picture
Last seen: 5 days 15 hours ago
You've posted this in the
You've posted this in the headphone section. You will probably get more responses in the hifi section
http://www.whathifi.com/forums/hi-fi
From my understanding you'd need a phono preamp to hook up a a turntable. Personally I'd go for the PMA 720 if I had the budget and the space, but then again it probably wants better and larger speakers than the 1010i.
Apple Mini -> Pioneer U-05 -> Adam A7X
ATV -> NuForce Icon HDP -> Genelec 8020C
Sennheiser HD650, HD595; B&W P7; Audio Technica ATH-AD900X, ATH-A900X
Log in to post comments
