Headphones for running
Can anyone recommend an inexpensive pair of phones for a fat bloke to run with?
I use Sennheiser CX300 at present but find I lose all bass as they constantly slip out of position.
I fancy trying an over ear phone, probably with the band around the back of the neck rather than over the head.
Any bright ideas and real life experiences would be much appreciated.
Always road running.
in that case avoid any that claim to block out noise or with mouldable plugs- you want to hear that car coming
Wise words fella, and of course those pesky muggers.
Depends what you mean by inexpensive. But you are describing the iGrado's... They are fabulous 'phones but are a bit leaky. Not a problem when running. They loop around the ear and have a neck band.
There is a set of philips that I got for my GF and they are very good, 5 stars as well. Think they are 8000/1 or something like that. Check in the review section under headphones (obviously lol) and you will find them there.
I have 2 pairs of earphones.
for Sports whether indoor or outdor I use the Bang & Olufsen A8, I baught them 3 years ago and been using them on daily basis, I just love them , they don't fall when running and they are very comfortable especially when using the pads ,sound quality is superb, if you want to save money ask someone travelling with British Airways to get them for you , . Other option Sennheiser & Sony both have a dedicated Sports line (weather and sweat proof) that should be cheaper than B&O, Note that the A8 can be repared and dealers stock spareparts, think of them as a long term investment.
Hope that was helpful
I use these:
http://www.amazon.co.uk/Sennheiser-PMX80SPORT-ECO-Neckband-Headphones/dp/B001IKKDL2/ref=sr_1_1?ie=UTF8&s=electronics&qid=1266860108&sr=8-1
They're very stable for running and sound good too.
If they are as good as the portapro ,Koss sportapro will give excellent results at a good price
- Login to post comments
treadmill running or road running?
