Headphones for home use
15 replies [Last post]
BigH's picture
Hello,
 I'm looking for some headphones for home use, need to be closed back as using in same room which has a TV on, so isolation is important both ways. Budget is around £140. Do not need too much bass, music is mainly 50s jazz, 70s rock and vocals with some folk/country/classical thrown in.
Looking at the Audio Technica ATH-M50 which are about £132. Should I consider any others like Audio Technica ATH-A500x?
plastic penguin's picture
RE: Headphones for home use
I'd be looking at these. Although not heard them, I've always been impressed with their other products - come with a hefty discount, too.
__________________
Amp: Leema Pulse; Source: Naim CD5i-2, Denon 260MKII, Pro-ject XP I; Speakers: PMC TB2i
Formerly known as plastic penguin
BigH's picture
Thanks but judging by the mixed reviews I don't think they quite what I'm looking for.
peza1's picture
I have these and find them excellent with most music. http://www.superfi.co.uk/p-10160-akg-k550-closed-back-headphones.aspx
BigH's picture
Yes I heard these are good but quite a few people complain about lack of bass.
 See this recent post: http://www.whathifi.com/forum/headphones-etc/headphones-for-home-listening
pauln's picture
Have you looked at the Beyerdynamic DT770 pro? Supposed to have good bass and well regarded.
__________________
On the road: HP Elitebook 8540w, Sennheiser HD650, Bose Computer Mini Monitors.
Home: Denon DBP-2010, Humax, Panasonic Plasma, Monitor Audio ASB-2, AKG K240 Studio, Audio-GD NFB 12, Audio Pro Addon T8 active monitors, definitely no fancy cables.
BigH's picture
Yes thats seems to be the only other one, a few negative reviews, not sure of the differences between 80 Ohms and 250 Ohms versions?
OneBoxSystem's picture
170 ohms?  puzzled Sorry.....
Harder to drive the 250 ohm ones and would possibly require a headphone amp. Can I pitch in these - though the price has crept up slightly:
http://www.amazon.co.uk/WeSC-Chambers-RZA-Premium-Headphone/dp/B0071HJ7BI/ref=sr_1_2?ie=UTF8&qid=1377195184&sr=8-2&keywords=wesc+chambers+by+rza+premium
Also, what about the £50 akg 451s?
pauln's picture
Your questions are probably answered in this comprehensive and excellent review by NwAvGuy: http://nwavguy.blogspot.ru/2011/04/beyerdynamic-dt-770-pro-80-review.html
Also some comparisons with other closed back cans.
__________________
BigH's picture
Thanks for those suggestions, I did see something about the WeScs that the sort of tips I'm looking for and £60 less. Just read a review on Amazon that says they are better than the AT 50Ms.
eggontoast's picture
IMO one of the best closed back headphones which isolate well, are comfortable and sound good are the Beyerdynamic DT770's. They have a reputation for being bass heavy which isn't true, they just have good bass extension which most headphones don't.
The Audio Technica ATH-M50's are also good sounding cans although I found them a touch sibilant on occasion, they are also not as comfortable as the Beyers, the big heavy coiled lead is also a PITA.
With regards to the WeSC RZA Chambers.....well your not 12 years old are you. Probably best left for the youths who can't pull their trousers up properly and wear their hats the wrong way around, innit.
BigH's picture
Thanks eggs some interesting opinions.
The other headphones I have come across are the Soundmagic HP100, similar to the AT 50Ms but more neutral, more revealing but in UK they are about £180.
Actually the AKG 550s maybe suitable as Im not a bass head although not a fan of lean sounding music either.
Beyers yes but maybe too much bass and the 80 Ohms and 250 Ohms may need a headphone amp? The 32 Ohms not sure if available here. A few reports of reliability problems.
AT ATH 50Ms, seem a good alrounder, neutral without being too revealing but maybe too much bass.
Soundmagic HP100, meant to be better than 50Ms but maybe to revealing, reliable? More money.
WeSC RZA Chambers, some say better than M50s, not very comfortable? Cheap.
BTW what is your amplification going to be ?
BigH's picture
At the moment it will be just from my soundcard which is a Xonar DG, which is quite loud, I currently use AT ATH-911s and I have to watch the volume is not too high when switching over to headphones.
You would undoubtedly require an external amplifier for the 80 or 250 ohm Beyers then, it would be better to seek out a 32 ohm pair.
BigH's picture
Just bought some nearly new Sennheiser momentums, over ear for about 1/2 RRP.
