Headphone Amp for Sennheiser 650
12 replies [Last post]
MoData
MoData's picture
Any recommendations?
__________________
Rega RP3/Exact/Phono -> Nait XS -> Kudos C2
idc
idc's picture
Re: Headphone Amp for Sennheiser 650
Check out the What Hifi headphone amp reviews, see what you like the look of, what is in budget and what has the features you need. I would add to that the Musical Fidelity X-CAN range, available second hand off ebay, but units still come close to their original prices as they are so well made. They are hydrid valve and solid state amps which have the power to drive all but the most in sensitive headphones, so the HD650s will be fine.
__________________
Internet - laptop - DAC - amp - lots of headphones.
http://idc1966.blogspot.co.uk/
"A music lover will stop what he's doing and stay glued to a favorite piece of music even if it's coming over a 3" speaker or a public-address system..." - Ken Rockwell
Mickgw
Mickgw's picture
I have a Little Dot III amp, i'm using with the 650's, works really well, i also have the AKG 701's but i prefer the 650's as the bass is better.
Hope this helps,
Mike
FlyingScot
FlyingScot's picture
Check out the Graham Slee reviews on the web. This one for instance.....
http://www.whathifi.com/Review/Graham-Slee-Novo/
Read his forum on his website too and you'll get a feel for how much care and pride he has for his products.
Graham_Thomas
Graham_Thomas's picture
Mickgw:
Ditto with Senn HD600s....
__________________
Mickgw
Mickgw's picture
Graham_Thomas:
Mickgw:
Hi Graham, how are you finding your amp?
I'm really pleased with mine and i'm happy i changed to the Senns, the AKG's are awesome but the Senns are just better with the type of music i listen to, does changing to the mullard tubes make a big difference? i dont really want to start going down the road of analysing the sound to the point of not enjoying the music anymore, i believe you can get upgraded cables for the HD650's but as i previously mentioned i'd only change if it was only going to make a noticable difference.
Thanks,
Mike
Graham_Thomas
Just a slightly warmer, more well-rounded sound with lovely bass and definitely an urgrade in my opinion for £20.
I believe from reading that the HD650 cable is the same wire gauge as the HD600 but with more shielding - with virtually no difference in sound quality.....
Save your money on esoteric cabling. I agree that we should just listen to the music and not over analyse - and stop tweaking!
__________________
peteAllen
peteAllen's picture
Burson HA-160 (£450), awesome headphone amp, and doubles up as a preamp. I have the 160D which has built-in dac with usb connection - really very very good piece of kit. The HA-160 was better than the Violectric and some say it is also better than the Lehmann Black Cube, MF xcans.
Also, a replacement cable can make a significant improvement. The Russ Andrews cable is superb - more detail, deeper & more defined bass and better sound all round really.
peteAllen
peteAllen's picture
For a lower budget you might consider the NuForce HDP - haven't heard it but it has an awesome reputation as a bargain and for working well with the 650s
MoData
MoData's picture
I've got a headroom MicroAmp/MicroDac stack, and really not very happy with it. (US$350 for the DAC, Ditto for the Amp).
Any ideas on whether the RheinLander that WhatHifi raves about would be an upgrade? What would be a good DAC to go with it?
Anyone done the Arcam rDac with a Headphone amp?
__________________
audioaffair
audioaffair's picture
The Graham Slee Novo is a great choice for HD650s. As an alternative choice, have a listen to the Creek OBH21SE as well if you can Yes
__________________
Maurice (Store Manager)AudioAffair, now including Faithful Audio
silly
silly's picture
I'd second the Burson, all their kit is top stuff, the KingRex HQ-1 is also a very transparent head amp.
KT66
KT66's picture
" I would add to that the Musical Fidelity X-CAN range, available second hand off ebay, but units still come close to their original prices as they are so well made. "
funny that. My x-cans fell to bits after a few months as did my old A1000, I think their build quality has been poor.
