Goldring NS1000 question
Should they hiss when you've got the noise cancelling turned on? They don't when it's off, but noticeable when it's on.
Yep, that'll be the soundwaves the headphones produce, designed to cancel out external sounds (as picked up by its microphones)
Thanks idc and Clare, was hoping it was something like that ![]()
Clare - is that really right?
I bought 2 pairs, one for me & one for the wife.
1 pair makes no hiss at all, the other pair does. Returned the hissing pair, only to have a replacement hissing pair.
Should I be returning the pair that don't hiss then?
Thanks in advance
Matt
Hi Matt, irrespective of hissing noise it should be clear in a noisy environment whether NR is working or not.
Thanks idc. My comment was more along the lines that if hissing is normal for sound cancelling headphones, then why does 1 pair not hiss? They are identical headphones apart from that.
Both pairs do cancel sound, however if they can make one pair without a hissing noise, why can't both pairs be like that?? Far nicer not having the hiss noise, so I want both pairs to be like it.
Awaiting the second replacement pair currently.
To clarify, when NR is switched on there is hissing in one and not the other and when NR is switched off there is no hissing in either?
idc:To clarify, when NR is switched on there is hissing in one and not the other and when NR is switched off there is no hissing in either?
Yup, that's correct
- Login to post comments
Yes, sounds like a bit of background tinnitus which should be drowned out by the music and only audible when there is silence.
Internet - laptop - DAC - amp - lots of headphones.
http://idc1966.blogspot.co.uk/
"A music lover will stop what he's doing and stay glued to a favorite piece of music even if it's coming over a 3" speaker or a public-address system..." - Ken Rockwell
