Goldring NS1000 Getting the battery in......
9 replies [Last post]
ziggy47
ziggy47's picture
Hi, had the Goldring NS1000 for a few days now, great value and SQ !!!!!
However I'm finding it difficult to open the earpod, to put the battery in.....I know that someone asked the same question last year, I've searched the forum, but cannot find the post.
So I'm hoping one of you helpful chaps/chappess' might help.....
Thanks in advance, Richard........
__________________
Hello!.....Hello!!.....Hello!!!.....I'm not waving, I'm drowning.......... help, I`m sinking
lazarus1803
lazarus1803's picture
Re: Goldring NS1000 Getting the battery in......
Grip the the cover on the right hand side ear-piece between finger and thumb - its turns anti-clockwise revealing a compartment for a single AAA battery
professorhat
professorhat's picture
Indeed, the key is not to try and pull the earpiece apart, but simply rotate the ear piece on its axis. Took me a little while to figure that one out too!
ziggy47
ziggy47's picture
Thanks guys for the help, still reluctant to force the issue..lol.......will attempt again...and again.....etc, Angrydamn, they won't beat me, but then again I said that about the wife (but that's something totally off the subject...Devillol)......Richard.
__________________
professorhat
Here's a photo of it open which should make it clearer what I mean (click on it to get the larger version):
GeoffreyW
GeoffreyW's picture
Hi, Zigster, yes,it's really that easy. The secret, as always, is in the wrist action. The battery's now in ok, and it would seem that it's needed to use the phones. Without the battery there's no sound  .Running in commenced. Cheers, Geoff.   'Doh.
__________________
Rega Planar 3/R200/Dynavector 10x4 > Arcam 640P > NaimUniti > NACA4 > Royd Doublets.      Alessandro MS1/Grado SR80/Fiio E7/L7.
Humax Foxsat-HDR / Panasonic DMR-BWT720 > Panasonic TX-P42G15B all through Uniti.
Binman
Binman's picture
You only need a battery in the compartment if you have the noise canceling activated.  Just switch it off if you have no battery in the compartment, and it will work.
ziggy47
ziggy47's picture
Hi Geoff, glad to see you were more successful than me.....they do work fine minus the battery, you did plug the lead in ?
Hope you are enjoying them, how do they compare to your SR80's ?
.....see you Monday..TTFN......d'oh....lol.............
RSJ...........
And a big thank you to the Prof, as usual a great source of info and help, cheers........HNY to all !!!
__________________
GeoffreyW
GeoffreyW's picture
Hi, Rich. Yes, I took the battery out and they still worked. I found the switch as well. The main difference is the lack of spaciousness I enjoy with my SR80s. But there's good detail, with accurate sounds, and they're still running in, and improving. And there's a considerable improvment, when they're switched on (with the blue lght on).  Had I not heard the Grados, I'd be quite imppressed, and I'm still tempted to buy, because of the lack of leakage, and I'd have to spend quite a bit more to significantly improve on the Goldrings, to get close to the Grado's sound. I listened to Metallic Spheres, and the effects seemed more pronounced on the Goldrings, though.  Things also got better when I changed the settings on the LD3 to suit the 300 ohm impedance Goldrings. With regards to comfort, they're very comfortable, once you've got the orientation sorted.
Hope your weekend goes well, see you Happy Monday,
Abyssinia,
F A Goode - Thyme
__________________
timbuzz
timbuzz's picture
RE: Goldring NS1000 Getting the battery in......
I have a Q about my NS1000 headphones (which I think have been very good value for the last 2 years) - and thought this might be an appropriate place to post it in case any user here can help me (Goldring expert please)?!
So they have been packed away for a couple of months and now, having got them out of pack, the laft ear seems to have a loose connection.
No sound until you tap or press on the earphone (pressure on the inside seems to prompt sound again)
so the question is whether anyone knows if I can get inside the unit and hunt for the issue too see if there is a bad connection somewhere I can easily fix.
I have tried gently forcing open, but am worried I will break casing irreprably the way I am going about it. Anyone know how to get in and repari without breaking?
thanks very much for any help!
