Best portible audio player (iPod)?
11 replies [Last post]
Kiwi_Jonno
Kiwi_Jonno's picture
Hey from NZ,
I'm looking for a mp3/portible music player. I'm not worried at all about movies, and good audio quality is the main aim.
Most of my music is in flac, though It wouldn't bother me to convert to apple loseless if I went down the iPod path.
Some I'v heard about are iPod touch, Cowon J3/D2+, Clip+, HiFiman-601.
I'm thinking the player would need to play a loseless format if it's going to have the best sound quality... are you Cowons as good as the reviews you read? The older D2+ looks like it sounds good even though its old. Is cheaper too... The Clip+ is meant to be a leader on S.Q also?
I use apair of Grado RS1 headphones, though possible get a smaller pair for travelling.
Thanks a lot!
bobshek
bobshek's picture
RE: Headphones, etc.
Best player for music, you gotta go with the Hifiman stuff.
Loyal following on Headfi!
bobshek
bobshek's picture
Wightknight
Wightknight's picture
I am very happy with my Cowon J3.
I regularly go to bed a couple of hours later than planned because I just wanted to listen to a couple of tracks first . . . .
__________________
Hi-Fi: Denon D-M37DAB, Monitor Audio BR1, Soundstyle Z2, Chord Company Carnival Silver Screen
Home Cinema: Samsung UE40D5520, Sky+HD, Sony HT-SS1200, PS3
Portable: Cowon J3, Beyerdynamic DT101ie
ostrichmilkman
ostrichmilkman's picture
i had a clip and a clip + that were both obscenely cheap they are still the best s q mp3 players ive ever heard and pack a fair amount of power too they never had trouble powering my hd202s or when i put them through my amp  plus the expandable memory is handy. just be carefull with them the clip was fine i put it through the washing machine and it was fine and then shut it in a car twice and the only thing that broke after the door was the screen. the clip + hower broke the day i got it and had to be sent back and i never quite trusted it after that.
sedish chef
sedish chef's picture
I've been thinking the same thing. I was going to buy a Fiio E7 to hook up to my IPod Classic.
With a Fiio E7 would it matter what what was your MP3 player .. I don't know?
Hobgoblinpie
Hobgoblinpie's picture
I have a J3, and wholeheartedly recommend it. Although the software isn't as intuitive as other products, the variety of formats you can play on it counteracts this in my opinion.
Unfortunately it does have a problem whereby ampersands are not recognised in artist names (it will cause the song to be moved to an Unknown artist), and AAC files will not have their bitrates read correctly (they will play fine, but the bitrate information will say 0kbps).
Sound quality is excellent though. I will however say that the output power isn't the best, so whilst it does get loud, unless you have noise isolating headphones, being outside may cause you to have a dimished listening experience.
chebby
chebby's picture
I'll vote for my iPhone 4. (Although I haven't ever used anything else but iTunes, iPods and iPhones so wouldn't have a clue what the rest sound like and can't be bothered to find out.)
I don't really have the inclination to faff around converting everything or changing from what I already know, works well for me and sounds good to me.
__________________
Marantz M-CR603 + AirPlay • Rega R3 loudspeakers • iPhone 5 32GB • iMac • Apple Airport Extreme 802.11n • Panasonic TX-L32D25B • Sony BDP-S390 • Ruark Audio R1 Deluxe • Humax HDR-Fox T2
caesar44
caesar44's picture
I'd go with Cowon stuff. It comes with nice features, and the SQ is awesome.
drichardb
drichardb's picture
Although I am currently a Sony user my next player (when I save some cash) will be a Cowon.  And as far as Apple is concerned, if sound quality is your priority then avoid them like the plague!!!
I've listened to the Clip+ and it's a superb little player!  If size is an issue you wont find anything better.
Whatever you buy I would recommend adding an amp to your setup, it will run your RS1's far far better than any player by itself could and it will also allow you to get the best out of any IEM's you choose to buy for travelling.
In response to sedish chef - it depends on the output.  If you use the normal headphone output to connect to any portable amp, not just the E7, then if your player doesnt have particularly good sound the amp will struggle to improve it or even make it sound worse.
I have tried my PA2V2 with several Apple players as you can probably gather from the start of this post I was not impressed!  In fact I felt they were just as poor with the amp as without, the only difference I found was it went louder with the amp and that simply doesnt cut the mustard for me.
__________________
My Setup
APPricot
APPricot's picture
RE: Best portible audio player (iPod)?
Currently I use Panamp iPhone app. It has basic iOS music player features, and it is outstanding by it's ability to make dynamic queues: quick mix of selected tracks and power search that quickly and efficiently find the artict, album and tracks. Most compatible with iTunes collection. See it here.  Feature that I like most - lock screen control
__________________
APPricot_in
peteAllen
peteAllen's picture
I prefer to use my (i)phone and just add a portable amp - recommend Pico Slim for IEMs, headstage arrow or rsa shadow or sr71b or probably the new Corda for full size
