Best headphones for a music lover?
I am a big music lover, who primarily listens to dance music and hip hop. I use the InCase Sonic Over Ear Headphones, which strangely enough for the relatively cheap price tag give me a more rounded, clear sound than many other headphones close to and slightly above their price range. I think the Dre Beats line are horrendous, even the higher end ones, and have yet to find a pair that offers me what I want: near perfect sound (I do not need actually perfect sound, just a sort of 'higher level' of sound than most people are used to).
Can anyone recommend me a pair of over ear headphones that are in the £200-400 (or about $300-500) price range? What I want is the best that money can buy, ones that are known for providing rich, clear, bassey sound. I like a good, very loud, thumping bass but having clear, distinct mids and highs are extremely important as well (I don't want them to be muffled by powerful bass). Another VERY important concern for me is comfort. The InCase Sonic phones are extremely comfy, and therefore I would want over ear headphones that have either foamy padding or leather for maximum comfort.
Basically, I'm an amateur, and need pros to tell me the best ones to get!
Your description of bass is more like a Philips L1 or X1 than a Sennheiser 650, since the 650 is fairly neutral. Another headphone that has good bass impact that may be even a better choice than the Philips is the Sennheiser Amperior.
Sennheiser hd650 is a good choice, they are very musical with a solid bass foundation. But do take note that they generally need a high quality heaphone amp to really sing. These are open back style headphones so does not give much "isolation" for outside noise aswell as that others around you will also hear some sound from them.
If you would rather have closed back headphones then Denon AH-D600 and Sennheiser Momentum are both nice alternatives.
In all cases try to audition pairs which have been "burnt in", since the sound from headphones generally change quite a bit with use.
Also agree with the Momentum and the Philips L1, but they are not the most comfy. Not bad, just not as good as the others.
Yeah, Beyer DT770LE - forgot that one, thanks Edd. Great choice.
......now if I had to live with one headphone forever it would be the HD600, which is very slightly less warm than the HD650.
They are good aren't they and comfortable to boot, not one for the bass heads though.
I would like to add that it might be nice to split some of the OP's budget off into a USB DAC / head amp if the listening is going to be done primarily from a computer.
