4 posts / 0 new
Last post
dadi84's picture
Last seen: 2 years 7 months ago
Best Headphones with controls and mic under £65
Hi all,
Can I get a bit of advice. I'm looking for a pair of Over ear headphones with audio controls and a microphone to listen to music and take hands free calls on my phone on the go. I previously bought "Bomber" Motorheadphones, but found them too uncomfortable. I also am limited to £65 budget. Can anyone recommend any that fit the bill? - Over ear, Audio Controls and Mic, Comfortable, up to £65.
Thanks in advance : )
dalethorn's picture
Last seen: 6 days 3 hours ago
dadi84 wrote:
dadi84 wrote:
Hi all,
Does "over ear" mean "around ear" or "on ear"?  Since both types are over ear.
Focal Elear, Beyer DT1770/T70p, Grado PS1000e, B&O H6, DragonFly1.2/DragonFly Black/Oppo HA2 DAC/amps, Lehmann Traveler amp.
JoelSim's picture
Last seen: 1 year 3 months ago
The Audio-Technica ATH-AX5iS
The Audio-Technica ATH-AX5iS is brand new and very good, as is the AIAIAI Capital which is a bit older but can be purchased for under £65 now.
Director
www.musictoyourears.co.uk
System: Unison Research Unico CDE with upgraded DAC, Leema Tucana 2, Kudos Cardea C2, AIAIAI TMA-1 Studio Young Guru, Beyerdynamic MMX102iE.
bigboss's picture
Last seen: 2 days 13 hours ago
That's a very specific budget
That's a very specific budget! Are you simply converting $100?
Log in to post comments
