Best closed headphones that won't leak sound?
4 replies [Last post]
tashlin
tashlin's picture
I need advice on the best 'all-rounder' closed back headphone please. In particular, I need a set of cans that I can use in my office that won't disturb my colleagues so any headphones that leaks out sound need not apply! Having researched a few reviews, I think I would like the sound of the Denon AH-D7000 but I am a little worried that these might leak out sound; any advice other owners of these cans can provide on this would be appreciated. I am also tempted by the new Beyer T5p, which reportedly isolates very well. However, I have read a few reviews that say these are quite bright/lean sounding. I am not a basshead and am very keen to avoid mudddy/boomy bass but I do enjoy a decent amount of bass slam/impact. Does anyone have a view on how the T5p sounds in this regard? Any other suggestions would also be appreciated! A few other comments about my kit/preferences: - I generally listen to lossless files but a headphone that won't render Spotify tracks unlistenable is highly desirable! - I use a separate DAC and headphone amp so driving higher impedance cans is not an issue - I have very broad music tastes but I listen predominantly to vocally driven music, such as rock, indie and accoustic. I also enjoy periodically listening to classical and jazz. Heavy dance/electronic music is probably my least listened to genre (but it does feature every so often!) - I have custom iems that I use for commuting. I don't really like using these in the office because I can't remove them quickly enough if someone comes over to speak to me or if the phone rings! - For home use I also own Grado PS1000 (which I love, except for really bass heavy tracks where it tends to lose control), Sennheiser HD650 (which is great for slower music or when a more forgiving approach is required), HiFiMAN HE-6 (which I generally find a bit too lean/bright and also quite 2 dimensional in terms of soundstage) Thanks in advance for your help!
tashlin
tashlin's picture
RE: Best closed headphones that won't leak sound?
Bump.  Come on - someone must have a view please!?
To summarise:
- I want a set of fairly high-end closed back headphones that don't leak out much sound to those around me.
- So far I've narrowed it down to Beyer T5p or Denon AH-D7000; does anyone have any comments on either of these?
- Any other ideas?
- Also, does anyone know anywhere in London I could listen to either of these before buying?
bennyboy71
bennyboy71's picture
Selfridges have headphones on show you can try out, but dunno if they have those models mate - check them out.
Otherwise, you could try the Tottenham Court Road electronics district but again not sure those specific models will be stocked.
What's your budget? Personally I use the Audio Technica ES7s currently when traveling and have a pair of ESW9As on their way in from the states currently. The ES7s are pretty good.
datay
datay's picture
I saw this when you first posted it, I think the thing is that since you own three sets of very high end headphones already, and a "custom-made" set for commuting, you are in a better position to judge this than 99% of the rest of us on here, perhaps apart from somone who can specifically advise you on the Denons or T5Ps. Hence, no responses.
Other than that, someone else recommended a shop on Tottenham Court Road on another thread, can't remember the name but I've been meaning to check it out myself. Can't be hard to find.
quadpatch
quadpatch's picture
Oh yeah I have been to that shop on Tottenham Court Road (also can't remember the name but it's on the left as you walk from TCR tube going north), there are a bunch of hi-fi shops set back a bit - a Samsung shop now too. Anyway I recommend checking that out if you can get to London fairly easily. I tried some Sennheiser HD600's and Grado RS1i's in there but they have loads, don't remember if they had Denons though, I was looking for AKG at the time which they definitely didn't have. Loved the Grados (as did my wife, she is a total Grado fan) but I don't think they were driving the Senn's properly. My advice is to take a portable amp if you have one.
Anyway I have since bought the Denon AH-D7000's and really love them!! but I should say that I also want the Grado RS1i's one day to compliment the Denon's characteristics. They are very powerful but the bass, as lovely as it is feels a bit coloured sometimes. I must point out that I wasn't a bass head until I heard these, they convert you I swear Tongue. I mostly listen to soundtracks which vary from Classical to Jazz to Electronic. I also like Metal / Grunge. I would say that the Denons are a great all rounder but I wouldn't want them to be my only pair so maybe you will be ok with them.
__________________
PC>JRiver> DAC/amps: FiioAudinstYulongArcamFostex, Audiolab, SchiitOppoIfi ●
Headphones: D7000Q701M80M100, DT770, DT880HP100HP200Mad Dog, HD650 ●
