advice on connecting a headphone amp-graham slee novo
2 replies [Last post]
simon3102000
simon3102000's picture
Hi guys, i think im gonna go for the above headphone amp so just a question on connection, from what ive read the best way to connect is through the tape out but also in the item description it says it can be connected to the pre-out... my amp has a pre-out that is connected to a mains in via a small plastic clip thingy, whats this all about? and is that the best connection for the headphone amp?
__________________
imac 2011, Airport express, DacMagic, NAD C326 amp, Wharfedale Diamond 10.1 speakers, Soundstyle Z1 speaker stands, chord cables, Tacima power conditioner. Controlled with my iphone 4S...
Andrew Everard
Andrew Everard's picture
Re: advice on connecting a headphone amp-graham slee novo
Yes, you could remove the jumpers between the pre-outs and power amp inputs on your NAD, then connect the pre-outs to the Novo's inputs, and the Novo's outputs to the NAD's power amp inputs.
However, this may have an effect on the overall sound of your amp, and of course the volume of the headphone amp will be affected both by its own volume control and that on the NAD.
I'd connect the headphone amp to a tape out on the NAD.
__________________
Consulting Editor, What Hi-Fi? Sound and Vision/whathifi.com  Audio Editor, Gramophone
simon3102000
Andrew Everard:
fair play, ill stick to the tape out.
__________________
