Advice on 2nd Pair of Headphones
41 replies [Last post]
Jason36
Jason36's picture
Hi Guys,
Following the excellent advice on here regarding buying my first pair of Headphones (SR80i's) I have decided I want to invest in a second pair of Headphones Smile (Yeah I know Eggontoast, you did say I would have a collection before long Smile )
This second pair of Headphones will purely be used with my laptop with more than likely a Firestone Fubar III or IV for itunes and spotify use. They will be used in both the office and at home. At home I would be sat in the lounge alongside my other half who will more than likely be watching TV at the same time.
Main criteria is that they mustn't leak noise like the SR80i's do...so probably looking at closed back designs and they must also be over the ear (rather than in ear.....I already have a pair of sennhesser CX300II's).
So far from a bit of research and my original thread I have come up with the following choices:
AKG K271 MKII
Sennheisser HD380 Pro
Audio Technica ATH-ES7
Audio Technica ATH ES55
At the moment I am probably leaning towards the AKG's.
Can anyone else suggest other alternatives, over the ear that dont leak noise up to £150.00
Cheers guys Smile
__________________
Main System: Laptop > Schiit Modi DAC & Schiit Magni HP Amp > Headphones
Portable: Rockboxed & Modded iPod (128Gb CF Card) / iPad4 / iPhone 4S / ALO National Amp / ALO Rx Mk3-B Amp / AlgoRhythm Solo DAC
Headphones: Sennheiser HD650 / Beyerdynamic T70p / Heir Audio A.4i IEM / Aurisonics ASG 1.2 / Sennheiser IE6 IEM
audioaffair
audioaffair's picture
RE: Headphones, etc.
From the models listed I'd suggest the Audio Technica ATH-ES7 as the leading choice. These are probably the most effective non-active closed headphones I've heard around £100 for not leaking sound. The ATH-ES55 are almost just as effective!
__________________
Maurice (Store Manager)AudioAffair, now including Faithful Audio
caesar44
caesar44's picture
Jason, which kind of music
Jason, which kind of music you like? coming from the sr80i's i assume you're a rock/metal lover, right?
Jason36
Jason36's picture
RE: Jason, which kind of music
To be honest, my musical tastes are very very varied....Yes I do enjoy a bit of rock things such as Red Hot Chilli Peppers, Linkin Park, Limp Bizkit, Led Zeppellen, Nirvanna etc etc. However I also listen to a fair bit of 70's stuff and also female vocals such Fiona Apple, Carol King, Linds Rondstadt, Rumour, Duffy, Isobel Campbell etc etc.
I find that the SR80i's are very very good and revealing / detailed for the majority of what I listen too but need a pair of closed back HP's for listening in close vicinity to other people....The SR80i's are staying as well Smile
__________________
caesar44
caesar44's picture
From the choices you listed,
I have to agree. The ATH-ES7's are good for what you listen.
Jason36
Jason36's picture
Cheers guys the ES7's look interesting.......If I was to up the price range to say £250 to £300 would there be any better suggestions bearing in mind the same criteria for listening??
__________________
Olli1324
Olli1324's picture
What about Senn HD650s for that money?
__________________
Member of the Trade
Epiphany Acoustics (headphone amplifiers)
eggontoast
eggontoast's picture
You could also consider the Denon AH-D2000's.
__________________
Sonos > M-DAC, Beyerdynamic A1, FiiO E17/E9, HLLY DMK-IV, STAX Lambdas, Denon AH-D5000, Sennheiser HD-600, Beyerdynamic DT770, MCA customs - Magnum V4's, Sennheiser HD-265 linear, Sennheiser CX300-II.
Jason36
Jason36's picture
Cheers Olli, but they are no good as they are open back.....as stated in the original post this second pair need to be closed back to reduce / eliminate noise leakage as they will be used in close proximity to other people.
__________________
Jason36
Jason36's picture
Cheers Eggontoast, they look just the ticket, they have got some very good write ups and seem as though they fit the bill for exactly what I am after....although I must say having looked at the AH-D5000's as well I am very taken by those, but they are considerably more expensive at £399.00. However I have a feeling that the mahogany finish on the 5000's is likely to provide a slightly warmer sound that the composite finish of the 2000.
Also both of these look a lot nicer than the Audio-Technica ES7, which I must say are probably a bit of an acquired taste design wise.
So it looks like the Denon's it is...now to try and find someone that stocks thenm locally Wink
__________________
eggontoast
Rumour on the head-fi and audiokarma is that the AH-D5000 is a bit of a sham and is not worth the extra cost. You are basically paying for the look of the mahogany cups, now the AH-D7000 that's a different story.....excellent cans which you would be very happy with I'm certain.
__________________
Jason36
Jason36's picture
Looks like it will be the 2000 then as I dont think I can justify spending £600 on a pair of headphones Smile not just yet anyway.
__________________
eggontoast
........its only money, just buy the misses a present at the same time and all will be well Wink
__________________
Jason36
Jason36's picture
Hmmm I wish it was that easy Smile
However having said that.....The Caspian Gear is up for sale at the moment as I am downsizing and re-jigging my system. New systems will be
Marantz MCr603 or Naim UnitiQute > Golding Phono Amp > Rega Planar 3 > Castle Speakers (this is to take advantage of the streaming capabilities.
Laptop > Fubar IV DAC / HP Amp > Grado SR80i's and obviously either the Denon 2000 / 7000
If I opt for the Marantz then that will leave plenty of cash for the Fubar and potentially the Denon 7000's which can be had for approx £588.00 (not sure what the RRP of these is but must be getting on for £700)
Smile
__________________
eggontoast
Sounds like it will be a nice system especially with the Naim streamer.
The RRP for the Denon AH-D7000 headphones is a hefty £899.99
__________________
Jason36
Jason36's picture
So £588.00 is a dam good bargain then by the sound of it Smile Maybe it will be the Denon AH-D7000. If they are that good then the Grado's may end up going as well (although I do love the sound of the SR80i's)
__________________
