Which SKY HD Box?
7 replies [Last post]
lastcoyote
lastcoyote's picture
Ok i'm about to get my sky+ upgraded to sky+ HD and just wondered if I should request a specific brand/model of HD box...if there is a choice that is. I remember that when I got my sky+ box I was recommended to request a Pace box for various reasons...less noisy etc..
Any Suggestions?
Cofnchtr
Cofnchtr's picture
Re: Which SKY HD Box?
AFAIK you cannot request the make of box unless you buy it from a shop. If you're buying from SKY directly, they have it in their terms that they supply whatever box is available at the time of install.
You could try and persuade them that if they don't supply a PACE you will not upgrade but that may or may not work.
Cheers,
Cofnchtr.
__________________
Panasonic TX-50GT30B | Pioneer VSX-LX53 | Pioneer BDP-LX54 | B&W M1 x 5 | REL Strata | SKY+HD 1TB | Harmony One Remote | Contentment.
daveh75
daveh75's picture
As Cofnchtr says, you cannot request any particular box from sky it's their policy.
__________________
lastcoyote
yeah..what i though. that's not changed since before then.
when i got my sky+ box i kinda just asked the guy who came in with one if he had a pace one on his van. he did and he let me have it. so i'll just try the same old trick again with the hd box.
what different brands/models are sky knocking out at the moment then?
daveh75
daveh75's picture
lastcoyote:
Sky are supplying, Pace,Samsung,Thomson and Amstrad boxes atm
__________________
gansta187
gansta187's picture
But haven't Sky started making all the boxes the same now? ie. One Sky+HD box, one Sky+ box and one Sky box? I've only seen 1 Sky+HD box
Cofnchtr
Cofnchtr's picture
The design of the outer case is identical on all new boxes but the innards or some of the components may be manufactured by any of the companies mentioned. IMHO.
I may be wrong.
Cheers,
Cofnchtr.
__________________
jay jay
jay jay's picture
I upgraded to a sky hd box a few months ago and they supplied a pace box. To put it simply its the nuts, i have never looked back, its quiet, fast and great picture quailty, please trust me, get the pace box.
