Television aerial connections for Freeview
Fri, Jul 11 2008, 3:25PM
I have just bought a new Samsung LCD which has Freeview built in. This new TV is in my living room but my television aerial socket is in my bedroom. Is there a way of connecting my new TV to the aerial via a wireless option. I don't want to have to pull up floorboards etc to connect.
Thanks in advance.
Fri, Jul 11 2008, 4:02PM
#2
Thanks a million John, sounds like the best idea
Fri, Jul 11 2008, 4:13PM
#3
Check out the CAI's installers page, or google aerialforce, who appear quite reputable.
Fri, Jul 11 2008, 4:22PM
#4
If you are going to get someone in,you may as well kill 2 birds and get the freesat dish put in at the same time to both rooms.Be cheaper in the long run.
- Login to post comments
No point in spending all that money on a telly and skimping on the feed by trying to use wireless. Get a man in to put up (or set up, if it's already good enough) a proper aerial, and route it to where you need it. Will transform SD television for you.
CA StreamMagic 6 | CA 751BD | CA 651A | PMC DB1i
Moderator. mail: john.duncan.whf at the mail of g dot com
